Author Topic: speedo trouble  (Read 1532 times)
dervdoc
  • Co.Armagh, N.Ireland
  • super turbo diesels
speedo trouble
« on: 15 September 2010, 14:14:26 »
on tickover the speedo needle flicks from 0-10mph, up and down fairly quickly, it does this for a while and some times sits a 5mph, its a 95 2.5td. also some times when i accelerate it sits at 5mph then shoots up to what ever speed im doing. anyone came across this issue?
many thanks
dervdoc
Re: speedo trouble
« Reply #1 on: 15 September 2010, 21:47:01 »
bump! anyone hazard a guess
Kneepad
  • West Scotland
Re: speedo trouble
« Reply #2 on: 15 September 2010, 22:02:12 »
OK a guess. Is the pickup for the speedo taken from the ABS sensor, could this be your problem.   :-/
dervdoc
Re: speedo trouble
« Reply #3 on: 15 September 2010, 22:08:45 »
i see your point but dont think this is the trouble as no abs light on oe even any intermitant faults stored on abs ecu
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: speedo trouble
« Reply #4 on: 15 September 2010, 22:09:31 »
I know you are clutching at straws, but I'd suggest not a feasible answer as the problem exists at idle (so I assume standstill).
Could be a number of things;
Faulty Dash Panel
Bad Earth
Dodgy Connection
etc etc
dervdoc
Re: speedo trouble
« Reply #5 on: 15 September 2010, 22:26:27 »
yea just wondering had anyone seen this before. might try a sender unit
Kneepad
  • West Scotland
Re: speedo trouble
« Reply #6 on: 15 September 2010, 22:31:33 »
Faulty Dash Panel
Bad Earth
Dodgy Connection
etc etc
No but  got the thread moving.   ;D
hotel21
  • The Kingdom of Fife
Re: speedo trouble
« Reply #7 on: 15 September 2010, 23:01:42 »
The sender unit are the ABS sensors...   ;)
The receivers are the guage on the dash.
As said, try reseating the head unit to ensure clean contact.....
VX1
  • Reading, Berkshire
Re: speedo trouble
« Reply #8 on: 16 September 2010, 18:55:46 »
I had this problem a little while ago and found that one of the pins behind the dash clocks wasn't touch te socket enough so any form movement to the clocks it would then make the speedo clock 'bounce' all over the place. All I done was to move the pin out a little more, carefully though, so It would make a proper contact, now I have a stable speedo needle no more bounce.
Vx Trade club card holder
Halfords trade card holder
dervdoc
Re: speedo trouble
« Reply #9 on: 17 September 2010, 16:37:00 »
had the dash out today any fiddled about with it but unfortunately the problem is still occuring, maybe try another dash unit in and see what happens
