Author Topic: code 71?  (Read 871 times)
duaneyb1
  • eastbourne
code 71?
« on: 17 September 2010, 19:39:52 »
need help with this fault code (air intake temperature voltage high) what could the problem be
i have checked the wires around the maf area and they all look ok. "My Naff Code Reader" air intake temp says 4.97v
Please HELP
many thanks :o
Re: code 71?
« Reply #1 on: 17 September 2010, 19:48:10 »
The air intake temperature sensor is in the elbow just before the MAF, not actually the MAF itself, according to my diagram - did you check that?
Worth unplugging the sensor wires and checking the resistance of the sensor and making sure it hasn't dropped to ~0..
Re: code 71?
« Reply #2 on: 17 September 2010, 20:00:11 »
Its a fair bet that its occured after some work....so check the air temp sensor and front multiram connectors have not been swapped round.
For info, the multiram is the longest lead
