Author Topic: knocking sound on 3.0 elite  (Read 1186 times)
omega V6
  • Suffolk
« on: 17 September 2010, 21:36:42 »
Hi all, i have a 3.0 elite and i have a knocking sound from the near side front when going along rough road or over speed humps. Any ideas of what this could be? thanks for reading, help appreaciated.
Re: knocking sound on 3.0 elite
« Reply #1 on: 17 September 2010, 21:38:52 »
Hi and welcome to the forum.
It sounds like it could be the drop links  ;)
« Reply #2 on: 17 September 2010, 21:40:06 »
Drop links are a good favourite  :y  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152986949
MV62960
  • Southampton
« Reply #3 on: 17 September 2010, 22:20:55 »
Hello,
Mine does the same thing (or at least similar), knocks when you turn the wheel or go over rumble strips. I've replaced the drop links, steering idler and both tie rods, but to no avail, infact it is gradually getting worse. Wishbones or the steering rack its-self are my next considered culprits.
« Reply #4 on: 17 September 2010, 22:21:58 »
Hello,
The Omega doesn't have a rack, its a steering box ;)
omega V6
  • Suffolk
« Reply #5 on: 17 September 2010, 22:26:26 »
I have also replaced all track rod ends, steering idler arm and the shaft that it comes of; i have forgotten what it is called and the problem is still there of course. An independant mechanic suspects it may be suspension mounts? thanks for all your replies.
« Last Edit: 17 September 2010, 22:29:21 by 3.0V6_elite »
MV62960
  • Southampton
« Reply #6 on: 18 September 2010, 08:25:13 »
They look nasty to replace (wishbones), but as your mechanic advises, they could be the problem. There is a good 'how to do it' on this site, which I will refer to closely to change mine. Then its that 'steering box' as I stand corrected, to look at. Though little info here on that bit.
