Author Topic: surrging  (Read 1077 times)
jordan890
  • manchester
surrging
« on: 19 September 2010, 07:54:13 »
after 10 to 15  minutes while on petrol the engine starts to surge i have cleaned the throttle body checked for cracks on the inlet manifold all seems to be ok the car is a 2 ltr duel fuel omega cd has eny one got eny ideaswhat could be causing this :-?
Malcolm_D
  • York
  • It shines!
Re: surrging
« Reply #1 on: 19 September 2010, 08:11:48 »
By surging do you mean that the revs keep going up and down on their own? If so is it doing this on idle? My problem was on a 2.5 V6 petrol, after getting warm on idle it would go from normal idle to 1200 rpm and back constantly.
jordan890
  • manchester
Re: surrging
« Reply #2 on: 19 September 2010, 08:15:49 »
yes thats what it is doing and it also speeds up by itself :-?
jordan890
  • manchester
Re: surrging
« Reply #3 on: 19 September 2010, 08:43:33 »
did you manage to fix this and if so what was causing it :-?
Malcolm_D
  • York
  • It shines!
Re: surrging
« Reply #4 on: 19 September 2010, 09:19:29 »
Don't ask me how much I wasted by getting the garage to attempt to fix it! The general consensus is that was an air leak somewhere on the breather side, Daz (Darth Loo Knee) had a quick look when he was over and he was certain that this was the problem. The trouble is that it can be a tiny leak and a pig to locate. I have had the plenum and breather pipes off a couple of times meticuously cleaning and checking that they are airtight, it appears to have worked although I never found anything conclusive. A further common cause is the idle control valve (ICV). If you are looking for expert help Daz is a man to talk to.  ;)
