Author Topic: Boiling up  (Read 1136 times)
b19oot
  • Stoke on Trent
Boiling up
« on: 18 September 2010, 17:52:30 »
After the palava with it loosing power i tried it and the temp goes into the red and the fan cuts in then the fan cuts off but the temp is still 100 if i undo the header tank an let the water/steam out the fan cuts back in an lowers the temp of the car like it was a massive airlock.
Does anybody know what this could be?   Headgasket?
markfree
Re: Boiling up
« Reply #1 on: 18 September 2010, 20:10:13 »
If you haven't any coolant in the oil then it's unlikely to be head-gasket.
Sounds like you could have a blockage somewhere in the cooling system - try flushing your rad, or could be kackered water-pump or even kackerted thermostat (stuck closed, but unlikely as when they fail they usually do so in open position)
b19oot
  • Stoke on Trent
Re: Boiling up
« Reply #2 on: 19 September 2010, 11:00:53 »
the oil cap is a little creamy just inside but this could be due to standing
Welung666
Re: Boiling up
« Reply #3 on: 19 September 2010, 11:46:01 »
That's common on the V's, take the filler cap off, take the neck off and refit the cap directly to the rocker cover. Clean the neck and stow it in the boot for oil change/top-up time. That'll hold off the mayo :y
Thermostats do jam shut aswell as open. You could try flushing the whole system out with just water and a hose just to make sure the waterways are clear.
Re: Boiling up
« Reply #4 on: 19 September 2010, 12:46:48 »
Where all the fans running?
b19oot
  • Stoke on Trent
Re: Boiling up
« Reply #5 on: 19 September 2010, 23:03:59 »
All? the main 1 does but like i sed it goes off then if i let out the air then it cuts bk in
Re: Boiling up
« Reply #6 on: 19 September 2010, 23:08:31 »
When its hot all 3 fans should be running ... :)
Quite a decent write up here ...
http://www.omegaowners.com/forum/YaBB.pl?num=1277831253
and some more at post #14
http://www.omegaowners.com/forum/YaBB.pl?num=1276355362
HTH
« Last Edit: 19 September 2010, 23:13:07 by entwood »
