Author Topic: broken locking wheel nut  (Read 3127 times)
sparks469
  • surbiton
« on: 17 September 2010, 03:09:25 »
hi all advice needed
on checking car found that a security bolt is broken any ideas how to get it out
cheers
markbrennan
dragonlord
  • luton
Re: broken locking wheel nut
« Reply #1 on: 17 September 2010, 06:25:02 »
whats it look like how is it broken
some are easyer that others
« Reply #2 on: 17 September 2010, 10:30:32 »
To be honest, ring a tyre fitting place (independents are often more helpful), they can sometimes get them off.
Failing that, its drilling it out :(
Oh, and all Vauxhall locking bolts are shit.  They are just about OK if used properly, and regularly retorqued, but that rarely happens.
Dave Elite
  • Ellesmere Port
« Reply #3 on: 17 September 2010, 12:42:03 »
How so?
« Last Edit: 17 September 2010, 12:42:55 by MV6Dave »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 17 September 2010, 14:21:59 »
If they are Vauxhall bolts and you have the code number they will supply a replacement for £27 otherwise you can look for full sets on the bay with the same key number, I had to go with the former due to mine being an old set
Teebee
  • Slough
« Reply #5 on: 17 September 2010, 14:35:01 »
I'll second that, i've just binned an old and a new set. The new set were the better of the two but the pin holes were becoming oval, the old set were plain horrible with it becoming difficult to get the locker in over the spinning collar.
I now have regular bolts only :)
hoofing it
« Reply #6 on: 17 September 2010, 15:38:20 »
cheers
As TB says go to a good tyre fitter.
ive removed a few and had to use the burning gear to heat the bolt up :y
OMEGA46B
  • EAST KILBRIDE
« Reply #7 on: 17 September 2010, 15:54:38 »
You can get special sockets in halfords to remove locking wheel bolts,cost about £16, you cant drill them they are hardened.
dragonlord
  • luton
« Reply #8 on: 17 September 2010, 16:15:45 »
screwfix do trhe kits as well
yea you can drill em with the right drill bit
just not you normal carp metal twist bit
try a PCD drill bit :y
mispent youth  ;D
« Last Edit: 17 September 2010, 16:21:44 by outlaw1234 »
dragonlord
  • luton
« Reply #9 on: 17 September 2010, 16:23:12 »
another way with many locking nuts is you can weld on a nut or cheap socket and undoem that way as well
Dave Elite
  • Ellesmere Port
« Reply #10 on: 17 September 2010, 16:43:27 »
They will not work as the VX locking wheel bolts have an outer sleeve that spins.
« Reply #11 on: 17 September 2010, 19:04:15 »
Not the prefacelift ones - both ours have the three pin type, no outer spinning sleeve :y
Hovelite
  • Sussex Coast
  • always look on the bright side of life!
« Reply #12 on: 17 September 2010, 23:12:42 »
The tyre fitters I went to couldn't do it.  Local man down the road had obviously been recommended before and knew what I was after when he saw the car before I'd even asked!
What's the point locking them with alloys that old anyway?
She passed the MOT!
whippit
  • Kirkcaldy, Fife
david036
  • Lancashire
« Reply #14 on: 17 September 2010, 23:53:31 »
Another way, but not the best is to remove the other wheel nuts, and slowly drive the car this will loosen the broken locking one works 99% of the time!!  Would reccomend only doing one wheel at a time....
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
