Author Topic: self levelling sussy , can it be changed ?  (Read 821 times)
skinwiz
  • northwest
« on: 26 September 2010, 15:51:33 »
just a quick question , and its one that  has probably been asked before but is it possible to fit standard/lowered shocks/springs to the rear when it currently has self leveling suspension fitted ? and if it is possible how do you go about stopping the air pump from suckin the life out of yer battery ?
please dont call me names , it just turns turns me on and i need BOTH hands to type .
Re: self levelling sussy , can it be changed ?
« Reply #1 on: 26 September 2010, 15:59:50 »
Easy job, just tie the air pipes up out the way and either pull fuse 27(I think) although rear 12v socket won't work either, or unplug the pump in the front drivers wing, but try and keep the connectors dry incase they need plugging in again later on.  :y
Shocks are easy job if the bolts are not seized, air pipes simply unclip.
« Last Edit: 26 September 2010, 16:01:06 by chrisgixer »
skinwiz
  • northwest
« Reply #2 on: 26 September 2010, 16:53:07 »
good news all round then  :) i thought it might not be possible , scared that they may have changed something by 1mm so you cant mess with it like rover tended to do lol ,
