Author Topic: suspension  (Read 1427 times)
david2310
  • croydon
suspension
« on: 26 September 2010, 23:01:54 »
can anybody tell me why omega's have 2 different springs on the front end and which side has the shortest
hotel21
  • The Kingdom of Fife
Re: suspension
« Reply #1 on: 26 September 2010, 23:03:27 »
Springs are the same length either side, front to rear.  In other words, axle pairs.  No one side is longer/shorter than the other.
david2310
  • croydon
Re: suspension
« Reply #2 on: 26 September 2010, 23:07:11 »
i have a w reg 2000 plate and when i phoned vauxhall and euro parts both told me that there are 2 different springs there handed but the only difference i can see is that 1 is shorter than the other
« Last Edit: 26 September 2010, 23:07:38 by david2310 »
hotel21
Re: suspension
« Reply #3 on: 26 September 2010, 23:08:24 »
Not 100% on the handed bit, but both should be the same free length and spring rate.
david2310
  • croydon
Re: suspension
« Reply #4 on: 26 September 2010, 23:09:24 »
ok now im really confused
Bent valve
Re: suspension
« Reply #5 on: 26 September 2010, 23:13:44 »
There will be at least 2 different spring types depending on model, but not 2 diffent types on the same car..
Re: suspension
« Reply #6 on: 26 September 2010, 23:20:35 »
springs are the same on both sides of the same axle. Its why buying in axle pairs is so important.
Front and rear axles are a differant design though.
Somebody on a winde up somewhere along the line i rekon?
« Last Edit: 26 September 2010, 23:21:17 by chrisgixer »
Re: suspension
« Reply #7 on: 26 September 2010, 23:23:45 »
if you have differant length springs on the same axle then one has broken off at the end. Tis common sadly.
2woody
  • Northumberland
Re: suspension
« Reply #8 on: 26 September 2010, 23:39:24 »
it is actually quite common to have different free length springs across an end of a car - it helps to even out the weight if one corner has a greater weight than the other. In race-car land it's called "cornerweighting", usually achieved by adjusting up or down the spring platform on the damper.
I have very occasionally seen different spring rates across cars as well, for the same reason.
I didn't think Omega B had either of these, tho
