Author Topic: omega 2.5 td - no power low down  (Read 3485 times)
chrism551
  • sunny blackpool
« on: 26 September 2010, 17:51:56 »
As above, my car seems to be totally flat on power upto about 2000rpm, when it seems to be adequate, high speed motorway (well 70mph ;)) smooth as silk. i have to apply about 1700 rpm to set off otherwise it will stall, defo no second gear set offs here.Anything which allows revs to drop below 1700rpm small hills etc in 4th means get out and walk because it would be faster. i have just run a paperclip test following guidance on here and i got code 12 and 74??
hoofing it
Re: omega 2.5 td - no power low down
« Reply #1 on: 26 September 2010, 17:58:53 »
code 12 is the start code and means nothing.
code 74 doesn't exist are you sure it's not 64.
chrism551
  • sunny blackpool
« Reply #2 on: 26 September 2010, 18:00:49 »
checked it twice, but i will check again and make sure. right have checked it again and the missus checked and it is deffo 74?? trust my car to be awkward :-?
« Last Edit: 26 September 2010, 18:22:41 by chris_m »
hoofing it
« Reply #3 on: 26 September 2010, 19:22:14 »
This got me on the fault code data sheet the last code is 65 then it jumps to code 81 as seen below
http://www.omegaowners.com/forum/YaBB.pl?num=1205270870
hoofing it
« Reply #4 on: 26 September 2010, 19:35:00 »
Does the engine managment light flash when you lift your foot off the gas whist driving :question
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #5 on: 26 September 2010, 19:53:49 »
new coil perhaps???
RIP Paul Lovejoy
« Reply #6 on: 26 September 2010, 19:56:07 »
new coil perhaps???
And where on a TD is that gonna fit ????
 :D :D :D :D :D :D
Webby the Bear
  • Northampton
« Reply #7 on: 26 September 2010, 19:57:48 »
if youve read any of my earlier posts youll know i know nothing about cars hahahahaa
 :y :y ;D ;D ;D
RIP Paul Lovejoy
hoofing it
« Reply #8 on: 26 September 2010, 19:58:38 »
new coil perhaps???
 :D :D :D :D :D :D
pmsl ;D ;D ;D ;D ;D
I thought I dropped some clangers ;D ;D ;D
hoofing it
« Reply #9 on: 26 September 2010, 20:02:28 »
chris update your user cp and add your location someone might be close by and able to have a look at the car for you :y
Webby the Bear
  • Northampton
« Reply #10 on: 26 September 2010, 20:10:47 »
RIP Paul Lovejoy
Kneepad
  • West Scotland
« Reply #11 on: 26 September 2010, 20:17:01 »
Check the small vacuum hoses on and around the egr solenoid and map sensor. Make sure they have not been connected on the wrong nipples and that none of them are blocked.
chrism551
  • sunny blackpool
« Reply #12 on: 26 September 2010, 20:30:06 »
No, the engine management light has never been on while driving, but i was wondering as the car was stored for more than four years whether the condensation/damp has allowed diesel bug to form. looking at the pics for stripping the in tank lift pump, its possible that the filter could be blocked with slime type substance and rducing the general flow of fuel to the engine, but this make me wonder if it would generate an EML fault for a fueling issue? :-/
chrism551
  • sunny blackpool
« Reply #13 on: 26 September 2010, 20:31:28 »
new coil perhaps???
 ;D ;D ;D ;D ;D
 :D :D :D :D :D :D
Kneepad
  • West Scotland
« Reply #14 on: 26 September 2010, 20:33:31 »
It's not a big job to pull the pump and check the filter. When I did mine it was about 80% blocked and no error code showing.    :y
