Author Topic: Help needed 2.6 v6 stalling and hesitation  (Read 936 times)
graham-mv6
  • Lisburn N.I
« on: 27 September 2010, 09:12:55 »
Hi everyone have problem hope someone can shed some light on situation when car is started the revs climb to 700rpm then drop to 0 cause it to stall unless i hit throttle, in which case its fine.  There also slight hesitation this doesnt happen to often.  I have been informwed coil packs have been changed so is it crank sensor? airflow meter? the engine management light has not come on at any point.
Thanks
Graham
Welung666
Re: Help needed 2.6 v6 stalling and hesitation
« Reply #1 on: 27 September 2010, 14:16:09 »
Try doing the pedal test (see link at the bottom of my post) to see if any codes are stored :y
