Author Topic: 2.2 Cat query?  (Read 3325 times)
arthill
  • Greenock
  • HI all pleased to join Forum
2.2 Cat query?
« on: 24 September 2010, 19:18:56 »
About a year ago I fitted new downpipe with Cat. I was assured by everyone it was the right one for my 2.2, but management light remains on and still shows catalytic fault. recently spoke to dealer and motor factor who still insist 2.2 only has one cat showing on all their catalogues, not the experience of members of this forum.any help appreciated thank you. :(
John
Welung666
Re: 2.2 Cat query?
« Reply #1 on: 24 September 2010, 19:53:28 »
What codes are you getting A?
arthill
  • Greenock
Re: 2.2 Cat query?
« Reply #2 on: 24 September 2010, 20:57:03 »
 Thanks for reply, not sure what code was, management light stayed off for a period after fitting new downpipe then came on again, had it read again showed catalytic fault, that is why I'm considering replacing it if it's faulty
John
Welung666
Re: 2.2 Cat query?
« Reply #3 on: 24 September 2010, 21:32:50 »
Ideally you need someone local with a reader to get the codes out of the ECU, that would help pinpoint the fault. There are a few Scot's members, hopefully one is close by and will pipe up (excuse the pun  :-[) and offer.
arthill
  • Greenock
Re: 2.2 Cat query?
« Reply #4 on: 24 September 2010, 22:06:08 »
I have read on this forum that 2.2 has a pre cat.Can anyone expand on that as no one new what i was talking about.
John
Re: 2.2 Cat query?
« Reply #5 on: 24 September 2010, 22:16:04 »
« Last Edit: 24 September 2010, 22:21:36 by philrich1064 »
arthill
  • Greenock
Re: 2.2 Cat query?
« Reply #6 on: 24 September 2010, 22:34:39 »
Thanks mate , picture shoes clearly two cats, dealer's picture does not look anything like that, I'll check it out. cheers. ::)
John
hoofing it
Re: 2.2 Cat query?
« Reply #7 on: 25 September 2010, 07:03:59 »
the pre-cat should have lamda sensors each side it and it was meant to be improve emissions.
also the cat in the centre section(under car) is only a half-cat.
Welung666
Re: 2.2 Cat query?
« Reply #8 on: 25 September 2010, 08:28:11 »
You have a later non-genuine cat. To save money they fitted a single cat box with a lambda either side. It should work pretty much the same though.
Re: 2.2 Cat query?
« Reply #9 on: 25 September 2010, 10:24:51 »
Except that the cheap pattern cats rarely last longer than 2 years and are mega noisey plus they are known to cause fault codes.
ALL 2.2 petrol Omegas had 2 cats, of that there is no arguement  :y
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Re: 2.2 Cat query?
« Reply #10 on: 25 September 2010, 11:30:53 »
I've seen another post 2001 non GM cat that has two boxes.
Omega 2.6 V6 Elite in Shiny Black
Re: 2.2 Cat query?
« Reply #11 on: 25 September 2010, 14:32:57 »
This link was in one of Proz's posts. Don't know if it is of any use to you, but worth a look? :y
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320396351654&ssPageName=STRK:MEWAX:IT
mark.adams
  • Cambridgeshire
  • Happy
Re: 2.2 Cat query?
« Reply #12 on: 25 September 2010, 18:27:00 »
arthill
  • Greenock
Re: 2.2 Cat query?
« Reply #13 on: 27 September 2010, 11:59:51 »
 What realy concerns me is that Vx.dealer insists there is only one cat. after logging my REG no, >:( >:(
John
arthill
  • Greenock
Re: 2.2 Cat query?
« Reply #14 on: 27 September 2010, 15:51:50 »
When correct cat is fitted, will EML go out its self or will it have to be switched off. :question :question
John
