Author Topic: Bonnet stuck shut... unless you press down..  (Read 1245 times)
« on: 28 September 2010, 19:17:39 »
I thought this might be a common one, but a search didn't turn up anything (at all.. or maybe my Search Fu is failing me today :))
The bonnet on the new Omega is stuck shut - unless you get someone to press down on it (as in pushing it closed) when you pull the release lever, in which case it pops open just fine.
Everything is nicely greased up down there, and the release mechanism moves freely when the bonnet isn't shut, but it's not doing it's thing when it is.
I tried winding the rubber stops for the bonnet out a bit earlier (making them longer) which did nothing, but thinking about it.. I should probably have wound them in to make them shorter, no?
Sanity check appreciated :) (I can't try it until I can persuade someone at work to give me a hand again tomorrow  ::) )
Welung666
Re: Bonnet stuck shut... unless you press down..
« Reply #1 on: 28 September 2010, 19:22:02 »
Try the maintenance guide index rather than search...
http://www.omegaowners.com/forum/YaBB.pl?num=1256423143
« Reply #2 on: 28 September 2010, 19:28:25 »
D'oh!
Thanks  :y
(I'll go and stand in the corner, now ;))
2woody
  • Northumberland
« Reply #3 on: 28 September 2010, 20:43:27 »
have you forgotten your "D" hat ?
« Reply #4 on: 28 September 2010, 20:46:59 »
Sorry Sir..
