Author Topic: Selector Switch?  (Read 2674 times)
pedroMV6
  • York
  • Der Metzgermeister
Selector Switch?
« on: 30 July 2010, 18:47:52 »
I think my selector switch is on it's way out.
Symptoms:
Most times (since Tuesday), after 15-20 mins, the spanner light comes on, and the 'box stays in top gear.
It still revs up OK and can reach illegal speeds, so I don't think it's the limp home mode being employed
I can use the gears manually, but it clonks a bit when moving up from 1st to 2nd.
did it again coming home tonight, stopped for petrol (ten mins max) got back into the car and all is well again.
Twice, it's been fine, so I'm wondering if it's either the switch becoming worn inside, needs some white grease or simply a connection/wire with a break in it.
Car: 2001 MV6 2.6 estate.
Any ideas on the most likely cause?
« Last Edit: 30 July 2010, 18:48:22 by PedroMV6 »
pedroMV6
  • York
Re: Selector Switch?
« Reply #1 on: 31 July 2010, 16:20:06 »
Nobody? :o
« Reply #2 on: 31 July 2010, 16:24:47 »
are the lights on the selector switch flashing or doing anything other than normal? Sounds like its just low on ATF. Check the level, on a flat surface, engine running, it should be level with the drain plug  :y
steve_daly
« Reply #3 on: 05 August 2010, 19:18:39 »
Any developments on this Pedro. Very interested as mine done exactly the same today.
« Reply #4 on: 05 August 2010, 19:30:09 »
Hmmm, any chance of any codes?
pedroMV6
  • York
« Reply #5 on: 05 August 2010, 19:32:59 »
Stopped doing it since the front wishbones were swapped out last weekend.
Perhaps the MPG will get better when it's tracked up!
Weird......
steve_daly
« Reply #6 on: 05 August 2010, 20:03:25 »
I'm sure I read somewhere on here I can't paper clip test mine :question
« Reply #7 on: 05 August 2010, 20:19:07 »
Some 2.2's can be 'pedal tricked' but they are quite rare
steve_daly
« Reply #8 on: 05 August 2010, 20:31:47 »
Pedal test didn't work.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #9 on: 05 August 2010, 20:43:32 »
Rufus. Have you checked your auto box oil level as per Tunnie.? in fact has the oil been changed in the last say 80k miles.
steve_daly
« Reply #10 on: 06 August 2010, 00:06:15 »
Gonna check the fluid levels yes.
As for when it was last done. The previous owner (and an oof forum member) did say it was done @ 90,852 miles. The mig has now just covered 102400 mies.
« Last Edit: 06 August 2010, 00:08:19 by steve_daly »
davethediver
  • Blackburn, Lancs.
« Reply #11 on: 06 August 2010, 00:48:30 »
Level shouldn't have dropped in 10k have you had the codes read yet rufus?
P.A. Caron de Beaumarchais
steve_daly
« Reply #12 on: 06 August 2010, 11:04:30 »
My mate who works for the local rozzers is on holiday for the week, so will have to wait a while till he comes back and can Tec II it for me.
pedroMV6
  • York
« Reply #13 on: 12 August 2010, 19:07:26 »
Started doing it again, so got it read tonight.
No codes.
Bet it's the selector switch or connections. ::)
Can someone point me in the right direction as to where I can find the selector switch and is there a gearbox ECU? If so, where's that please?
« Reply #14 on: 12 August 2010, 19:11:38 »
No codes.
http://www.omegaowners.com/forum/YaBB.pl?num=1267956397 and ECU is behind driver`s kick apnel
