Author Topic: Rear blind help please  (Read 3539 times)
Bourne
  • Essex
  • Stupid tiny glovebox !
« on: 24 September 2010, 19:35:39 »
Can anyone tell me if it's possible to retro fit an electric rear blind into a rear parcel shelf without one?
I can get a blind ,but its not in a shelf.
If so , what's involved. Mine has bose setup under the shelf by the way . Is this a problem - Thanks.
« Last Edit: 24 September 2010, 19:42:24 by Bourne »
Welung666
Re: Rear blind help please
« Reply #1 on: 24 September 2010, 19:49:21 »
The easiest way is to get an Elite rear shelf with the blind still attached. As long as yours has the cabling in for the blind that is :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 24 September 2010, 20:24:30 »
And if you are interested in one (fully working) PM me.  :y
« Reply #3 on: 24 September 2010, 20:36:32 »
As  said, easiest way is to find one the right colour with shelf and fit that, although some have cut the original shelf, then plug and play, just pull the blank out the dash and push the new button in.
My shelf was very firmly glued in by the rear screen sealant so would not come out easily, and be careful not to let the bolts on the shelf under side damage the speakers when it does comes out.
Bourne
  • Essex
« Reply #4 on: 24 September 2010, 21:12:10 »
Thanks guys. - Broomies mate - PM sent
dbr
  • north east.
    • 1997. 2.5CD petrol
« Reply #5 on: 25 September 2010, 00:37:11 »
plug n play switch. front left of boot will be a conector for it. very simple job , did it  on 97 cd
boughtonthecheap
  • Probably on a road somewhere
  • Not all things that go 'UP' come 'Down'
« Reply #6 on: 25 September 2010, 09:18:29 »
..Hope you managed to sort out a blind for your car, I never had a car with a rear blind before it would be really useful but I tried to get my blind to work & it just makes a clicking noise... :-[
skyblue
  • Bracknell
« Reply #7 on: 25 September 2010, 17:12:32 »
Please advise a real thickie ;) ;D Just got a 02 cdx and want to get a rear blind fitted in mine  and was wandering if all the conections for the blind are there or do I need to get other bits apart from the switch, blind and rear shelf
« Reply #8 on: 25 September 2010, 17:43:33 »
In the boot, left hand side under parcel shelf, connector lives there. Just plug and play
skyblue
  • Bracknell
« Reply #9 on: 25 September 2010, 17:52:28 »
Thanks  mate..... even this thickie understands that ;D ;D
Ploppy
  • Norfolk
« Reply #10 on: 26 September 2010, 23:06:33 »
Mine does the same, just clicks .....if I find out if I can take the blind apart will let you know..
Ploppy :y
dbr
  • north east.
« Reply #11 on: 26 September 2010, 23:44:20 »
Ploppy :y
think thats a cog problem.....I had one that went up ok but would not go down. It would go for 2 seconds and then start clicking
skyblue
  • Bracknell
« Reply #12 on: 27 September 2010, 20:59:49 »
Is the parcel shelf pre marked on the underside  for cutting out the strip for the blind ???? as I may have to resort to this as im hitting brick walls in trying to find a shelf in black that is pre cut
Malcolm_D
  • York
  • It shines!
« Reply #13 on: 27 September 2010, 21:50:41 »
Re blind not working just making clicking sound.
Suggest that you disconnect power connection - inside boot high up on the left at the back, try it again, if no clicking then it is getting power. Mine was the same, followed the guide on the OOF guide section to remove shelf and blind unit. Then dismantled the mechanism unit, I was lucky in that the spindle of one of the cogs had jumped out of its bush, reassembled and it worked great. Pig of a job to get the shelf out, watch for the bolts fouling on the bose speaker units.  ;)
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
« Reply #14 on: 28 September 2010, 13:26:20 »
Had the same issue on mine, press the button and hear a click from the area of the back shelf, but no blind deployment.
I was working up to taking it all out and dismantling it, then one day I thought 'I wonder if it will work with the engine running' and lo! it did! Had to rev to about 3k rpm, but it works every time.
Possible battery issue? :-/
« Last Edit: 28 September 2010, 13:26:51 by djac »
Page created in 0.028 seconds with 16 queries.
