Author Topic: Noisy starter motor  (Read 1382 times)
Noisy starter motor
« on: 28 September 2010, 09:15:03 »
I've noticed it seems to be making a metallic noise of late, like somethings rubbing when the starter motor engages, will have a look when I get a chance, anything I should be looking for? Never even looked in that area before tbh... :-/
It's something I've heard on other cars before and thought "ooh, that doesn't sound right"
andyc
  • Norfolk
Re: Noisy starter motor
« Reply #1 on: 28 September 2010, 09:18:50 »
Your not having much luck with this one. All i can say is sort it sooner rather than later.
The Starter on the Nova had been making a funny sound for a while until one Saturday moring outside Tesco the starter sezied, good job we were on a hill.
Most of the time you can get a starter re-coned for alot less that a new one but you  might be without the car for a day or so
Cheers
Andy
Thetford. Norfolk
« Reply #2 on: 28 September 2010, 10:53:14 »
Unheard of to get issues with the starters on all but the 6 pot derv.
« Reply #3 on: 28 September 2010, 19:09:46 »
Ear plugs  :-/ ;)
« Reply #4 on: 28 September 2010, 19:35:23 »
Worth checking the motor hasn't worked loose on its' mounting bolts?
« Reply #5 on: 28 September 2010, 22:18:07 »
mine serviced some time ago.. but its not an easy out job..  :-/
position of starter a bit fiddly ..
« Last Edit: 28 September 2010, 22:24:07 by cem_devecioglu »
« Reply #6 on: 29 September 2010, 00:01:05 »
Good stuff Cem.
Brushes worn out? (the black carbon bits?)
« Reply #7 on: 29 September 2010, 09:50:16 »
Could be those reduction gears getting a bit graunchy, I suppose?
Then again, I was standing next to your car when you started it on Sunday and don't remember hearing anything out of the ordinary.
I was still half cut from the night before though.
« Reply #8 on: 29 September 2010, 12:56:26 »
Good stuff Cem.
yep.. they are all changed with new , the copper parts were sanded.. and inner gears oiled.. :y
« Reply #9 on: 29 September 2010, 13:04:29 »
Good stuff Cem.
la la la, I'm not listening
« Reply #10 on: 29 September 2010, 17:41:59 »
Good stuff Cem.
 I have seen this procedure several times for some cars.. they sand it only to enough to shine.. whats wrong with it ?
« Reply #11 on: 29 September 2010, 18:02:34 »
Good stuff Cem.
You should NEVER abrade a comm......the most you can do at home is polish it up with a bit of Brasso.
It should go on a laith, the trouble with sanding is that it results in a com that is slightly out of round and that does not have perfect edges to the segments (only small but it makes a difference).
This risks the segments raising and causes premature brush failure.  :y
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #12 on: 29 September 2010, 19:21:41 »
If you have to replace it and go for an exchange alot of factors will supply you with a unit(some charge a deposit) then you can just replace the one on the car minimising the time the car is off the road and return the fubard one to the factors later.
« Last Edit: 29 September 2010, 19:22:33 by Tony_H »
