Pages: [1] 2 3  All   Go Down
Author Topic: 3.2 cams in 2.6????  (Read 5914 times)
DodgeyDave
  • Northumberland & London
3.2 cams in 2.6????
« on: 20 September 2010, 20:25:16 »
If you upgrade the camshafts on a 2.6 V6 to the 3.2 camshafts is it just a straight swap or do other bits need changing too?????
I've heard you can gain quite a bit more power doing this but is it as straight forward as it sounds.
« Last Edit: 20 September 2010, 20:25:45 by awjadamson »
Re: 3.2 cams in 2.6????
« Reply #1 on: 21 September 2010, 17:27:11 »
Cams are a straight swap. Will need new cam cover gaskets while you're at it. Intake divider and manifold can also be changed as they are slightly larger on the 3.2.
Might as well change the cam belt and tensioners while you're there.
I may be wrong but I believe 3.0 cams would do the same job. Might make it easier to find a set?
DodgeyDave
« Reply #2 on: 21 September 2010, 21:05:24 »
Thats great, thanks for your reply, i'm gonna be doing the cam belt and pulleys soon so i think i'll do this at the same time.  :y
Any idea what the effect will be on fuel consumption?
2woody
  • Northumberland
« Reply #3 on: 22 September 2010, 23:50:48 »
I know I gained 12 horsepower by putting back 2.6 cams in repacement of the 3.0 cams in mine !
DodgeyDave
« Reply #4 on: 23 September 2010, 15:13:02 »
I might be being a bit thick here, but do you mean you put 3.0 cams in a 2.6 engine and gained HP? :-/
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #5 on: 23 September 2010, 16:36:14 »
i would think thats whats meant ;)
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #6 on: 24 September 2010, 08:27:20 »
hi all sorry to butt in but can i ask about cams as well i believe i can put in 3.0's in my 2.5 ? and where would be best place to find replacement cams etc many thanks  :)
« Reply #7 on: 24 September 2010, 08:56:27 »
You must have had some other fault!
DodgeyDave
  • Northumberland &amp; London
« Reply #8 on: 24 September 2010, 14:01:18 »
I've heard you can get up to +25hp by putting 3.2 cams in a 2.6. I'm gonna do my cam belt soon with the help of the forum DVD so i was thinking about doing this at the same time while i have it in bits.
I justy want to know if all i do is take the old cams out and put the 3.0/3.2 ones in?? or if i NEED to change anything else :-/
« Reply #9 on: 24 September 2010, 14:06:07 »
Yes, and try one of the breakers on here.  Wise to put on a 3.0l divider plate as well
DodgeyDave
« Reply #10 on: 24 September 2010, 14:06:28 »
Best place to source the parts from a 3.0 would be to find someone who's breaking one or go down the scrap yard and see what they have. I believe they used the 3.2 litre engines in Isuzu's aswell :y
« Last Edit: 24 September 2010, 14:08:52 by awjadamson »
davethediver
  • Blackburn, Lancs.
« Reply #11 on: 24 September 2010, 18:35:04 »
Make sure you have a proper locking kit :y
P.A. Caron de Beaumarchais
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #12 on: 24 September 2010, 18:39:19 »
as The Boy says, if fitting 3.0 cams its worth fitting a 3.0 inlet divider too. you could always port the openings on the 2.5 heads too as i found them to be slightly smaller than the 3.0 (pic of my c25xe with 3.0 inlet divider below)
PM with your requests.
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #13 on: 24 September 2010, 19:44:03 »
thanks for your help and sorry for butting in will speak nicely to members on scottish meet if any of them can help,im a complete numpty when fixing things.
many thanks again :y
2woody
  • Northumberland
« Reply #14 on: 24 September 2010, 20:41:35 »
I bought a 2.6 that already had 3.0 cams in it.
did a before and after dyno check to find that I'd picked up horsepower when I went back to the original cams.
I'm actually planning to test the theory once-and-for-all soon.
Pages: [1] 2 3  All   Go Up
