Author Topic: Unknown Output Driver Error  (Read 3965 times)
Dave Elite
  • Ellesmere Port
« on: 30 September 2010, 19:24:24 »
Paper cliped my 3.0 v6 and got code 136 (Unknown Output Driver Error). Any idea what that is? Thanks
Re: Unknown Output Driver Error
« Reply #1 on: 30 September 2010, 19:52:31 »
It means the car thinks your a sh!te driver. :y
Dave Elite
  • Ellesmere Port
« Reply #2 on: 30 September 2010, 19:54:17 »
Wasnt expecting that, very clever. I take it you dont know then?
« Reply #3 on: 30 September 2010, 20:05:45 »
clear it (with code reader), if it reoccurs, ignore if not causing issue, or replace ecu
Kneepad
  • West Scotland
« Reply #4 on: 30 September 2010, 20:06:11 »
Maybe something to do with this:
put you are foot on the brake and handbrake on, when u turn the key move the gearstick from park all the way down  and back again,while turning the key,
Abiton
« Reply #5 on: 30 September 2010, 20:08:32 »
Discussion of same here
Haven't read through to see if it is solved.
Dave Elite
  • Ellesmere Port
« Reply #6 on: 30 September 2010, 20:10:38 »
Thanks, Didnt have to do that in the end, the wife said the car just started fine.
Dave Elite
  • Ellesmere Port
« Reply #7 on: 30 September 2010, 20:12:35 »
Car is running fine, eml light flashed up a week ago when i was stuck in traffic for two hours. I've only just got round to reading the code.
« Reply #8 on: 30 September 2010, 20:14:59 »
Hmmm, 137 is ecu over temp...
Dave Elite
  • Ellesmere Port
« Reply #9 on: 30 September 2010, 20:17:26 »
I think it was the heat of the engine. Do you think the heat could have caused a temporary fault with one od the sensors?
  • Auckland
    • Mazda MPV
« Reply #10 on: 30 September 2010, 20:17:52 »
If you do find a fix I think Omegafantasy would be delighted to know what it is  :y
V6 Fault Code 19 & 136
Plumbing The Beast
[edit]note to self - must type faster ::)[/edit]
« Last Edit: 30 September 2010, 20:19:55 by andyh »
Dave Elite
  • Ellesmere Port
« Reply #11 on: 30 September 2010, 20:19:59 »
Plumbing The Beast
Will do. Its not causing any trouble. I think it was just the heat of the engine (2 hours in a traffic jam). And the light hasnt come on since.
« Reply #12 on: 30 September 2010, 20:21:57 »
Dave Elite - are you getting a 19 as well?  I've seen them throw a few erroneous other codes (usually MAF codes though)
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #13 on: 30 September 2010, 20:22:09 »
The Omega I've just stripped had a fan mounted in the wing, it was connected to the e.c.u./relay box via a tube...
Maybe your fan is not working or the ducting is loose/blocked?
Dave Elite
  • Ellesmere Port
« Reply #14 on: 30 September 2010, 20:25:00 »
No TB, just 136. Do you think I should ignor it? as the light hasnt come on again.
