Author Topic: Torque setting, drop links and wishbone ball joint  (Read 1141 times)
« on: 01 October 2010, 10:37:28 »
V6 torque values in maintanance shows steering knuckle to ball joint 100    And.  3.   Under notes
Is this the correct setting I want for the wishbone ball joint clamp bolt? What does 3 mean? I know there are only 2 bolts one each side.
Or am I looking at the wrong thing?
Plus, anyone know the correct torque setting for drop link nuts.
Ta
2woody
  • Northumberland
Re: Torque setting, drop links and wishbone ball joint
« Reply #1 on: 01 October 2010, 11:24:15 »
is that not the front-rear aligned bolt in the knuckle ?
« Reply #2 on: 01 October 2010, 13:00:29 »
Yes, holds the ball joint on the outboard end of the wishbone.
Or at least that's the torque setting I want.
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 01 October 2010, 14:17:41 »
Ta
Tight??
Sorry chris might not help but I couldn't find it last week either so nice and tight is what I went for ;)
P.A. Caron de Beaumarchais
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #4 on: 01 October 2010, 14:36:06 »
FWIW Haynes gives 65Nm both ends   :y
I feel like a military academy. Bits of me keep passing out.
markfree
« Reply #5 on: 01 October 2010, 14:37:53 »
Lower balljoint to knuckle is 100nm/74lbs ft.
Anti-rollbar link rod to strut 65nm/48lbs ft.
Doubt if you would get a torque wrench on top nut tho. :y
Kneepad
  • West Scotland
« Reply #6 on: 01 October 2010, 14:51:13 »
From TIS:
Attach guide joint to steering knuckle – insert fastening bolts from front towards rear – tightening torque 100 Nm / 74 lbf. ft
Kneepad
  • West Scotland
« Reply #7 on: 01 October 2010, 14:56:10 »
Drop links - tightening torque 65 Nm / 48 lbf. ft.
Welung666
« Reply #8 on: 01 October 2010, 15:41:28 »
Quite easily. Left side on full left lock with only the top connected. Right side on full right lock again with only the top connected. My 120nm fits nicely then.
« Last Edit: 01 October 2010, 15:42:12 by Welung666 »
Page created in 0.063 seconds with 16 queries.
