Author Topic: ecu connection  (Read 3736 times)
Kneepad
  • West Scotland
ecu connection
« on: 01 October 2010, 15:34:16 »
On the ECU backplate there are two spade connectors on a small black component (switch)
or sensor ? anyone know what it does ??
(Edit)Better picture.
« Last Edit: 01 October 2010, 18:58:27 by Kneepad »
Omegatoy
  • UK
Re: ecu connection
« Reply #1 on: 01 October 2010, 18:51:13 »
not sure but i think its a thermal fuse?
Kneepad
  • West Scotland
Re: ecu connection
« Reply #2 on: 01 October 2010, 19:02:23 »
Thanks,  one of the spades has broken off. doesn't seem to make any difference, but wanted to know what it is.
Re: ecu connection
« Reply #3 on: 01 October 2010, 19:04:44 »
Looks like it to me. I wonder if it's to activate the cooling fan for models so equipped?
Kneepad
  • West Scotland
Re: ecu connection
« Reply #4 on: 01 October 2010, 19:10:24 »
Which fan are you thinking of Kevin ?
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: ecu connection
« Reply #5 on: 01 October 2010, 19:19:43 »
I believe in hotter climates, there is a fan to keep air circulating around the ECU.
I could however be very wrong  ;D
Kneepad
  • West Scotland
Re: ecu connection
« Reply #6 on: 01 October 2010, 19:23:23 »
I'll have a look tomorrow, though I don't remember seeing any fans near the ecu.
Who would have thought that in tropical climate up here.
Re: ecu connection
« Reply #7 on: 01 October 2010, 19:35:20 »
 ;D
It was lovely when I was up there in early September. Bet it's changed for the worse by now! ;)
And yes, some models have a fan to cool the ECU box. Only think I can think of. :-/
Kneepad
  • West Scotland
Re: ecu connection
« Reply #8 on: 01 October 2010, 19:38:10 »
It's pi**ing it down now. Probably the monsoons.
  • Woodhall Spa, Lincs
Re: ecu connection
« Reply #9 on: 01 October 2010, 19:44:35 »
Fan for cooling the ECU/fuse box lives against the 'A' piller under the passenger front wing, and blows air via a tube to the fusebox. Had them on all 3 of the omega's I have had (MV6, 2.5 V6 and TD)
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
Re: ecu connection
« Reply #10 on: 01 October 2010, 19:53:19 »
It's pi$$ing down down here in France too. ;)
Kneepad
  • West Scotland
Re: ecu connection
« Reply #11 on: 01 October 2010, 20:01:08 »
 :y  Well done young man, that'll be why i've never seen it.    :y  :y
« Last Edit: 01 October 2010, 20:01:55 by Kneepad »
Abiton
Re: ecu connection
« Reply #12 on: 02 October 2010, 13:07:51 »
Just looked on our (2.0/16V ultimate base model) car - whilst looking for the non-existent fan test connector -  and there is just such a temperature switch, and it's wired up (one brown wire, one brown with blue trace).
It can't be to switch on any ECU cooling fan though, because there is no air ducting whatever into the triangular box.  Maybe if it registers that the ECU is too hot it brings on the main (only on ours) rad fan?  :-/
Might have a browse at the wiring diagrams if I get bored later...
Re: ecu connection
« Reply #13 on: 02 October 2010, 13:10:34 »
Pretty certain its a temp sensor.  I had one you could of had until last night (gave the ECU away)...
Kneepad
  • West Scotland
Re: ecu connection
« Reply #14 on: 02 October 2010, 14:56:14 »
Ah well, it's the thought that counts.   :y
Just had another look. Can't see any air pipes going into the box. If, with ign on, I short the connections I hear a relay click on. Can't determine which one. Had to give up, Bl&&dy church bells 30yds away, can't believe someone would go an die while I'm trying to fix this.
