Author Topic: Missfire when cold only  (Read 2215 times)
Hovelite
  • Sussex Coast
  • always look on the bright side of life!
« on: 17 September 2010, 23:03:10 »
Am chuffed to bits that the elite has got through the MOT only requiring one rear shock due to frequent trips over speed bumps!!  :y
As a complete novice can anyone explain why the beast only has a missfire when cold and purrs fine once warmed up.  Is there an easy fix to this?  :-?
I do lots of short journeys but even the day after a run the issue remains....
She passed the MOT!
Re: Missfire when cold only
« Reply #1 on: 22 September 2010, 16:37:39 »
check your sparks for carbon deposits..
check your plugs..
check for air leaks when the engine is cold..(spraying a carb cleaner)
try a compression test..(this is done without sparks)
omega hell
  • bedford
« Reply #2 on: 03 October 2010, 13:48:15 »
Could be short journeys so the engine does not get up to temp,and/or not using the revs very high,both will cause carbon build up on the valves and plugs giving you these symptoms.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 03 October 2010, 16:29:58 »
Check there is no water in your plug wells too  :y
Page created in 0.027 seconds with 16 queries.
