Author Topic: Changes to air con pipework on later models?  (Read 777 times)
Malcolm_D
  • York
  • It shines!
« on: 03 October 2010, 23:14:37 »
After discussing an air con leak with several members it appears that the pipe config on both of my V6 elites is different to other later models? The pipe I am referring to is part no 90564650 and goes from the bulkhead, onto the right hand side chassis leg, under the ABS module, under the battery shelf and out to a joint with another pipe. It is going to be a pig to replace but it also appears that VX changed it, I was wondering if anyone knows what change was made and if there is a different (later) pipe which might fit and make my life easier?
If you read this Cliff I would be interested in looking at the engine bay of your 03 3.2 model when we meet  :y
Alternatively does anyone know of an air con specialist who makes pipes to order so that I can re-route it myself?
