Author Topic: fault codes  (Read 1725 times)
jim513
  • london
fault codes
« on: 03 October 2010, 13:22:00 »
Hello all
Just done a paperclip test and got 55 followed by 4 quick flashes and 31 can someone verify what the 55 and 4 and what no RPM signal means please.
thanks Jim
Kneepad
  • West Scotland
Re: fault codes
« Reply #1 on: 03 October 2010, 13:35:33 »
Check it again code 4 does not exist.
55   Replace Electronic Control Unit (ECU)
31 just means your engines not running.
jim513
  • london
Re: fault codes
« Reply #2 on: 03 October 2010, 13:45:18 »
I checked again and i still got 55 followed by 4 quick flashes the reason i done test in first place is because i've broken down in kent and greenflag cant get me going reckons it might be a crank sensor would that be the 31 fault code
Jim
Kneepad
  • West Scotland
Re: fault codes
« Reply #3 on: 03 October 2010, 13:55:15 »
Jim
19   Incorrect RPM Signal  Crank sensor.
jim513
  • london
Re: fault codes
« Reply #4 on: 03 October 2010, 13:59:38 »
Ok thanks mate....back to scratching my head then.
Kneepad
  • West Scotland
Re: fault codes
« Reply #5 on: 03 October 2010, 14:26:56 »
One of our experts will be here in a sec. with some advice.   :y
brian36
  • Milton Keynes
  • 2.6 mv6
Re: fault codes
« Reply #6 on: 03 October 2010, 19:04:37 »
hi folks also have 19 code and unsure where best place to buy the genuine crankshaft sensor as stealers give me 2 kinds and unsure which one but prices vary between 60 and 100 any input please many thanks
« Last Edit: 03 October 2010, 19:04:56 by brian36 »
Kneepad
  • West Scotland
Re: fault codes
« Reply #7 on: 03 October 2010, 19:14:25 »
Try a PM to AndyC, a member on here who can post you genuine parts at trade club prices as he is a parts manager for Vauxhall.   :y
brian36
  • Milton Keynes
  • 2.6 mv6
Re: fault codes
« Reply #8 on: 03 October 2010, 19:19:07 »
many thanks for that have a good day  :y
Re: fault codes
« Reply #9 on: 04 October 2010, 09:04:02 »
3.0 take same as 2.6/3.2, despite what EPC tells them.  2.5 can have either, but normally the more expensive one.
