Author Topic: Poss alarm issue  (Read 1449 times)
Rainmaker
  • Cirencester
Poss alarm issue
« on: 03 October 2010, 19:34:29 »
hi all ive recently joined so new to this site, i have an mv6 and the alarm goes off every 2 hrs any clues at all on how to stop this..it has a brand new battery...
Kneepad
  • West Scotland
Re: Poss alarm issue
« Reply #1 on: 03 October 2010, 19:45:13 »
Power sounder has it's own battery, i.e. not the main car battery.
Check the bonnet switch is locating properly.
Kneepad
  • West Scotland
« Reply #2 on: 03 October 2010, 19:54:33 »
You may want to consider disconnecting it until you sort it out:
http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #3 on: 03 October 2010, 19:59:02 »
Hi Rainmaker, welcome to the forum.   :)
... and could you ease off just a little bit on the rain making?   ;D
Your problem sounds a bit like this one, which has links into various suggestions for fixes.
If it turns out to be the power sounder, I have just sorted this on mine and it wasn't too bad to fix - only one box of elastoplast required.
Hope this helps!   :y
I feel like a military academy. Bits of me keep passing out.
Rainmaker
  • Cirencester
« Reply #4 on: 03 October 2010, 20:26:47 »
Hope this helps!   :y
well ya cant please everybody eh! ill try my best to avoid more ok...
Anyways is it ok just to remove these batteries and everything still works apart for the infenral sounding alarm ie. still locks etc just no noise/alarm going off in the middle of the night
Kneepad
  • West Scotland
« Reply #5 on: 03 October 2010, 20:44:33 »
No other problems associated with disconnecting the sounder. It may impact on your insurance though.
Rainmaker
  • Cirencester
« Reply #6 on: 03 October 2010, 21:22:35 »
so just uplug for now sort the batteries then reconnect it up when fixed...
Kneepad
  • West Scotland
« Reply #7 on: 03 October 2010, 21:25:22 »
Rainmaker
  • Cirencester
« Reply #8 on: 03 October 2010, 21:45:04 »
Sorry missed that post Doh! will sort as soon as..thanks again...
unclelicklug
  • Sheffield
« Reply #9 on: 04 October 2010, 12:44:34 »
Hi and welcome
If you have found your remote locking operation to be a bit sketchy then I'd recommend you get that looked at, mine was hit and miss for a while and around the same time the alarm started going off in a more or less random fashion - I got the key fob repaired by Martin Imber http://www.martinimber.co.uk/ and the alarm has been fine ever since.
As many will confirm Martin is a top guy and turned my fob round very quickly and reasonably.
And yes - enough with the rain!
