Author Topic: Steady 4500rpm for 15mins... Blown HG?  (Read 2258 times)
24_Valve
  • Greater London
« on: 27 September 2010, 01:38:31 »
In a desperate attempt to drop my emissions for fast idle test a local MOT garage unofficially locked my throttle at 4500rpm for 15mins to see if CO would drop below 0.3%
Now I have white smoke from tail pipe  >:( Could this engine speed for 15mins blow my Head Gasket? The mig was already nice & warm but she is 14 yrs old  :(
Is it likely or maybe just coincidental...
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
Re: Steady 4500rpm for 15mins... Blown HG?
« Reply #1 on: 27 September 2010, 08:25:15 »
Is white smoke the only symptom?
Abiton
« Reply #2 on: 27 September 2010, 08:56:56 »
Did they make damn sure that it didn't overheat during this strange 'treatment'?
« Reply #3 on: 27 September 2010, 11:03:18 »
Hm :(
Along with the other questions; do you get the white smoke all the time (it's just got much colder outside, so you'll see much more than you were a week ago..) and is it overheating now at all?
« Reply #4 on: 27 September 2010, 11:29:29 »
pull sthe sparks out and test with a rope if its wet or not.. or try a compression test..
ps : also coolant loss will be very visible from the tank..
« Last Edit: 27 September 2010, 11:39:32 by cem_devecioglu »
24_Valve
  • Greater London
« Reply #5 on: 27 September 2010, 14:12:39 »
thanks for all the replies; white smoke is the only symptom I've noticed... Don't know if they made sure it didn't overhead? unofficial print off showed engine oil temp 112 degrees? not overheating since I've had it back... but will keep an eye! no coolant loss  :y
« Last Edit: 27 September 2010, 14:13:24 by silvercross1 »
« Reply #6 on: 27 September 2010, 14:21:00 »
112! Damn.. I have to have sustained periods of high boost on the track car to get it up that high - no wonder oil change intervals are short on the Omega if that's normal :)
« Reply #7 on: 27 September 2010, 14:31:41 »
112 degrees will presumably be the oil temperature via a dipstick probe. In which case it's not unreasonably high.
As said, I hope they kept a close eye on the coolant temperature since if there was a problem with the cooling fans it could have overheated.
Otherwise, I would say it was on its' way out anyway. No worse than sitting at 4500 RPM on the motorway autobahn with load on it.
.. and a drive on the motorway would have done a better job of purging it, IMHO.
24_Valve
  • Greater London
« Reply #8 on: 27 September 2010, 20:07:08 »
I hope so too  :(
afaik the fans are working fine but to be on the safe side I'm gonna test them using the method outlined by Dave AW http://www.omegaowners.com/forum/YaBB.pl?num=1276355362/15 just not sure if I've got the correct number layout for the test socket... thanks kw  :y
24_Valve
  • Greater London
« Reply #9 on: 03 October 2010, 22:39:43 »
Posted bt Aaronjb
Update: no more white smoke, not overheating at all (sat in very heavy traffic yesterday for over an hour, no probs), no coolant loss & no mayo in filler neck... Panic over, HG is fine  :y I'll be a bit more careful who I let play with her next time  ;)
« Reply #10 on: 03 October 2010, 22:57:37 »
Good news  :y
« Reply #11 on: 03 October 2010, 22:59:33 »
Yes, that is good news indeed. :y :y
« Reply #12 on: 03 October 2010, 23:01:58 »
« Reply #13 on: 04 October 2010, 07:59:50 »
That is good news!, you can now revert back to being a normal mildly neurotic Omega Owner.  :D ;D ;D ;D ;)
24_Valve
  • Greater London
« Reply #14 on: 04 October 2010, 23:25:09 »
thanks guys  ;)
