Author Topic: Locked in Park  (Read 1425 times)
SR-71 Blackbird
  • Watford and Nottingham Uni
Locked in Park
« on: 06 October 2010, 13:38:55 »
Hi everyone,
in the last two days the gear has been stuck in park when i have started it up and then it wont release and allow gear selection in normal. i have to press the brake many many times to activate it and now im leaving it neutral in case it never comes out of p and i cant drive it anymore. Before Marks DTM may have sprayed somthing on a sensor or somthing and it seemed to help for a while, i was wondering if i could do somthing similiar and what should i use and where should i spray etc, pictures would be great because then i can see exactly what to do etc, unless its another problem that is , thanks
Re: Locked in Park
« Reply #1 on: 06 October 2010, 13:48:56 »
Under gearlever is a yellow lever to release parking lock. It`s either the sticking solenoid in pic or a dodgy brake switch up under brake pedal. Pop up gaiter surround to access
« Last Edit: 06 October 2010, 13:49:38 by RobG »
Re: Locked in Park
« Reply #2 on: 06 October 2010, 13:49:11 »
There is a small solenoid in the gear lever assembly that operates when the brake is pressed; it sounds like yours is getting lazy in it's old age..
There's actually a picture and description of what to do to manually release it in the owners manual:
http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf
Page 139.
You can try lubricating that lever mechanism and solenoid.
[edit] Must .. type .. faster. ;)
« Last Edit: 06 October 2010, 13:50:52 by aaronjb »
SR-71 Blackbird
Re: Locked in Park
« Reply #3 on: 06 October 2010, 14:02:09 »
i think marks dtm did somthing under the brake pedal, does anybody have a picture or guide of how to do that, as that seemed to fix the problem last time, thanks
Re: Locked in Park
« Reply #4 on: 06 October 2010, 23:17:28 »
replace your brake pedal switch  :y
SR-71 Blackbird
Re: Locked in Park
« Reply #5 on: 07 October 2010, 00:15:27 »
what kind of spray should i use on the solenoid? WD40? would that be ok?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Locked in Park
« Reply #6 on: 07 October 2010, 11:46:38 »
Use a silicon spray - not WD40.
I like red cars
Page created in 0.023 seconds with 16 queries.
