Author Topic: Omega Timing Marks  (Read 1025 times)
Alan J C
  • Woodsetts
Omega Timing Marks
« on: 07 October 2010, 13:44:44 »
Hi there. As a first posting hope someone can help a very exasperated DIYer. If not a bit desparate!
I own an Omega 2.2 CDX auto. engine Z22XE, and had to be towed following a cambelt failure. I changed the cambelt but the engine shows no sign of life whatsoever. Turns over fine so presuming no engine damage. Believe I may have set the cambelt wrong as the markings are very confusing. (Using Haynes manual) In addition to the usual markings there x2 yellow dots on both camshaft sprockets. The camshaft cover markings are also painted yellow.
On the cranshaft I cannot find any `cutout` to align to. There is a single white dot adjacent to a screw hole and a vague yellow dot/mark on the inner side rim - and nothing I can see to align this to, if relevant.
I would be most grateful if someone could advise me how to determine the correct timing markings and alignments.
The local Vaux agentes answer is £50 `recovery` and ? whatever cost of repair  - which is not very encouraging!!
Any help would be really appreciated
Alan C
Welung666
Re: Omega Timing Marks
« Reply #1 on: 07 October 2010, 13:46:30 »
Where are you Alan?
Alan J C
  • Woodsetts
« Reply #2 on: 07 October 2010, 13:49:25 »
Woodsetts. Worksop. NOTTs
2woody
  • Northumberland
« Reply #3 on: 07 October 2010, 13:54:17 »
has it got any compression - you could still have a nice set of bent valves there !
« Reply #4 on: 07 October 2010, 13:56:27 »
If the cambelt went then there will be bent valves.
Is it spinning over quite fast
Alan J C
  • Woodsetts
« Reply #5 on: 07 October 2010, 14:00:41 »
Not sure how to test for that one. Needs quite a bit of strenth/elbow to turn over. With cambelt off both cams turn full circles without any `apparent` problems.
Alan J C
  • Woodsetts
« Reply #6 on: 07 October 2010, 14:06:46 »
The engine appears to be turning over as per usual. Not noticebly any faster.
Welung666
« Reply #7 on: 07 October 2010, 14:26:55 »
You need a compression tester really to test it properly.
Alan J C
  • Woodsetts
« Reply #8 on: 07 October 2010, 14:52:25 »
Thanks.
Will see what I ca do.
Page created in 0.021 seconds with 16 queries.
