Author Topic: auto gearbox  (Read 1923 times)
Richie London
  • heathrow
auto gearbox
« on: 07 October 2010, 15:45:16 »
stripped the plenum this morning, cleaned everything, egr blanked off with coke can. still no change,decided to take the car to mates to see if he knew why it was running so bad.
started to slip gear and then thump into 2nd gear.by the time i got home it wouldnt even move in gear. jacked up drivers side to check level and i think about 4 litres came out brown and very thin so obviously its had it. cleaned the gear selector which was rotten.
now.. because i couldnt even move in gear will there be something major wrong or does it just need new filter, clean and refill with new fluid. i'm burnt, aching stressed and gonna drown me sorrows in a bottle of JD.  ;D ;D
Richie London
  • heathrow
Re: auto gearbox
« Reply #1 on: 07 October 2010, 16:00:58 »
anyone know the name of the place that does the gearbox filter, is it j pat or jp oils ??or similar
Re: auto gearbox
« Reply #2 on: 07 October 2010, 16:05:30 »
http://www.jpat.co.uk/Parts_cat_GM.html is the one you're looking for, I believe.
If oil came out of the level check/fill bung when the car was on level ground then it must have had plenty in .. but thin & brown means burnt, which to me would suggest brake bands and/or low hydraulic pressure.. but I'm definitely no automatic transmission expert!
Richie London
  • heathrow
Re: auto gearbox
« Reply #3 on: 07 October 2010, 16:15:15 »
thats what came out raised up drivers side, it poured out like water, and frigging red hot all over my arm  :( ;D ;D
Re: auto gearbox
« Reply #4 on: 07 October 2010, 16:17:42 »
Ahh gotcha, sorry I'll put my glasses on now  ;D
In that case it could just be old ropey fluid .. worth doing a drain and refill anyway, what's to lose? :) (Aside from more skin  ;D)
Richie London
  • heathrow
Re: auto gearbox
« Reply #5 on: 07 October 2010, 16:33:32 »
ive just ordered the filter, so gonna be another day stressed out for me tomorrow
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: auto gearbox
« Reply #6 on: 07 October 2010, 16:50:54 »
Good luck with it, I hope an oil change and new filter sorts it out for you.
How many miles has it done?
Richie London
  • heathrow
Re: auto gearbox
« Reply #7 on: 07 October 2010, 16:56:19 »
102k now. if it doesnt work then the car will be scrapped monday morning, even though ive spent 300 this week
sassanach
  • trowbridge
Re: auto gearbox
« Reply #8 on: 07 October 2010, 20:33:46 »
bit extreme isnt it? scrapping a motor for the sake of a slushbox. or am i missing something?
Kneepad
  • West Scotland
Re: auto gearbox
« Reply #9 on: 07 October 2010, 20:41:41 »
Don't do anything rash. New fluid and filter may be all that it needs.
If your taking the gb sumps off you could check the solenoid. There was a thread quite recently about this.
Richie London
  • heathrow
Re: auto gearbox
« Reply #10 on: 07 October 2010, 20:51:22 »
ive stripped it today again trying to find out why its running so bad, no power at all, loads of codes come up yesterday so fed up. i'm now thinking could it be the fuel filter as it seems starved of petrol trying to accelerate,or too much petrol cause it got through about 7 quid of petrol not going anywhere,thats starting and stopping the engine outside the house, but fuel filter was replaced just a few months ago  :-? :-?
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: auto gearbox
« Reply #11 on: 07 October 2010, 21:12:27 »
Was the engine running when you checked the level.  If it wasn't running you will get oil pouring out.  Check must be done with the engine running.
thats what came out raised up drivers side, it poured out like water, and frigging red hot all over my arm  :( ;D ;D[/quote]
Kneepad
  • West Scotland
Re: auto gearbox
« Reply #12 on: 07 October 2010, 21:16:16 »
This is getting confusing, as you start a new thread re gearbox, then revert back to bad running issues. Had to start hunting to find your old threads.
Are the sensor you are replacing being replaced with new or used parts?
You appear to have created more error codes when you changed the maf. Try disconnecting it completely and see if there's an improvement.
You say the fuel filter was changed. Have you checked the filter on the lift pump in the boot?
Richie London
  • heathrow
Re: auto gearbox
« Reply #13 on: 07 October 2010, 21:30:29 »
sorry, got so much going on in my head at the moment.
extremely stressed out.
all new parts except mass sensor. dont know anything about a lift pump though. not very mechanically good.
can hang 8 doors in an 8 hr day though  ;) ;D ;D
Kneepad
  • West Scotland
Re: auto gearbox
« Reply #14 on: 07 October 2010, 22:00:30 »
Now you got me confused again. The one in the boot is for the Diesel engine.
Try this for the estate but should be similar to yours:
 http://www.omegaowners.com/forum/YaBB.pl?num=1177279323
Page created in 0.024 seconds with 16 queries.
