Author Topic: dis pack replacement  (Read 2360 times)
Richie London
  • heathrow
« on: 14 October 2010, 15:53:46 »
possible "its had it" going by the water stains on it from when the hbv went 6 months ago. so hopefully can get sorted now tomorrow. what bolts are they and whats the best tool to remove it.
i'm sure there is a diagram of where the leads goon the plugs and pack, i cannot find, and i dont want to put them the wrong way round when i put back together once ive ripped me hands to shreads tomorrow
Sixstring
  • Lydney, Gloucestershire
Re: dis pack replacement
« Reply #1 on: 14 October 2010, 16:02:49 »
Easy job, Richie, but fiddly and time consuming.
where are you?
you will need a full set of "torx" sockets, from 6mm to 19mm, a dry place inside a garage, a load of cloth to block holes off with, and a half day to spare. Use a tipp-ex  spot to mark the plug caps, and prepare for bruised knuckles and scratched hands.
Give me a pm and I'll talk you through it by phone if you need it.
Mike.
Richie London
  • heathrow
« Reply #2 on: 14 October 2010, 16:08:02 »
where are you?
Mike.
the plenum is off, holes are blocked and shrink wrapped, i'll take the scuttle off in morning and the cable trunking to get better access. i've a nice silver marker to do the leads.
any idea what size torx i need to get it off??
amba
  • Medway towns
    • German V6
« Reply #3 on: 14 October 2010, 16:14:48 »
Sure the bolts holding the dispack in place are torx 8mm from memory.
Some are fitted vertical as were mine and I found the best method was a 1/4 drive short extension on a swivel connected to a long extension..it looked a bit of a contraption but did make access easier.
Most of the work is done by feel unless you are quadruple jointed but once scuttle is off and also suggest wiper motor aswell it is not too bad..just expect a few bruises and scuffs to the skin.
I twisted a selection of coloured wire loops onto the leads to identify which way they went back as found white tippex was very messy and difficult to see when had dirt on them.
Best of luck with it.
Sixstring
« Reply #4 on: 14 October 2010, 16:18:09 »
mine is 7mm torx socket, there are 4 bolts to feel for in the corners of the dispack, they WILL be tight and a bitch to feel for, if you have a "wibbly-wobbly" for your 3/8" drive it will be helpful.
The oval plug is easier removed before trying to get the dispack out, (it WILL be a b*tch to get out, bend the r/h engine mount over temporarily and it will come out upside down easily) and don't forget to spray the plug with carb cleaner before you fit it onto the new one as it will be mucky and won't seal on the new one otherwise.
TOP TIP.........put a blanket overthe whole engine when you are leaning over it, so if you drop something it wont go into the engine, or on the floor, put the blanket over the wings side to side, and cover the entire engine.
good luck mate!
Malcolm_D
  • York
  • It shines!
« Reply #5 on: 14 October 2010, 16:23:14 »
good luck mate!
Like the 'top tip' I lost a torx socket somewhere in the engine bay when it dropped off the extension when I was changing the DIS. I had blocked off all of the ports etc... so no worries there but it was one socket of a brand new set  >:( >:( Still has not turned up!
Richie London
  • heathrow
« Reply #6 on: 14 October 2010, 16:37:56 »
good luck mate!
disconnected already.   ive got a long bendy bit that goes into my torque drill,
Sixstring
« Reply #7 on: 14 October 2010, 16:55:08 »
GREAT!! straightforward if not a PITA then.
Gotta do mine again soon, these s/h ones don't last long, this one only lasted 11k......................
mike
Richie London
  • heathrow
« Reply #8 on: 14 October 2010, 17:09:34 »
mike
just hope the one i have is the right one. its a bosch thats all i know  ;D ;D
dragonlord
  • luton
« Reply #9 on: 14 October 2010, 17:13:11 »
like others say wipe off plenum stick some rags in
i dident bother with tipex etc as dis is numberd and its number marked on cam cover as well so want really and isue
i found the eayest way to undo torx bolts was with a flexable 1/4inch nut driver and tightly tape on the socket on the end with inserlation tape so it cant come off and you spend 3 looking for it in engine
or god forbit it gos down the inlet port if you forget rags or one rag slips
not that hard just a pain
Richie London
  • heathrow
« Reply #10 on: 14 October 2010, 17:31:19 »
i am so looking forward to ripping my hands to break like the first time i did the hbv.
dragonlord
  • luton
« Reply #11 on: 14 October 2010, 20:56:19 »
they heal up lol
mine are starting to stop hurting lol and it about 4days since i done it.
that said back still killing me was at doc this morning for a 100 x30 codiene
lol have fun
that said my back was fooked to start  with
dragonlord
  • luton
« Reply #12 on: 14 October 2010, 21:09:00 »
oh year when i spoke to vx stealer they said that there was more than one per year so had to have number off dis unit first
hope its right one m8
david036
  • Lancashire
« Reply #13 on: 14 October 2010, 21:37:08 »
When I got my dis pack, it turned out that there are 3 common ones, and one other thatdoesn't get listed!!  Can you guess which mine was!!!!! :) :)
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
Richie London
  • heathrow
« Reply #14 on: 14 October 2010, 21:52:35 »
no  ;D ;D ;D
