Author Topic: 2.2dti clutch  (Read 1587 times)
hawksy
  • crewe
2.2dti clutch
« on: 12 October 2010, 14:24:54 »
my 2003 omega 2.2dti elite has now covered 160,000 and the clutch seems to be starting to give up the ghost , i am in vauxhall tradeclub and they tell me clutch will be £ 200.00 plus vat . How much should i expect to pay for fitting and is it a difficult job . regards mike
Welung666
Re: 2.2dti clutch
« Reply #1 on: 12 October 2010, 16:00:24 »
Sounds about right for the clutch as it includes the slave cylinder and thrust bearing as one piece. I normally charge around £100 and takes about 4 1/2 hours :y
hawksy
  • crewe
Re: 2.2dti clutch
« Reply #2 on: 13 October 2010, 10:59:33 »
thanks for the info very much appreciated, but this morning whilst having 2 rear tyres fitted a mechanic told me that the flywheel may also need to be replaced , is this correct as i believe they are about £ 300.00, regards mike
Welung666
Re: 2.2dti clutch
« Reply #3 on: 13 October 2010, 11:07:52 »
If you buy one from Vx! They're around the £150 mark. Do you get any funny noises with the engine running and your foot down on the clutch? Metallic clank or clack noises?
hawksy
  • crewe
Re: 2.2dti clutch
« Reply #4 on: 13 October 2010, 11:13:01 »
no noises at all , i bought the car 3 years ago with 34000 miles on from vauxhall main dealer , it now has 160,000 and has never missed a beat , the only reason i am asking is that the clutch pedal seems to feel different than it normaly does , ie not as springy on the return , regards mike
Welung666
Re: 2.2dti clutch
« Reply #5 on: 13 October 2010, 11:20:08 »
That'll be because the pressure plate is weakening with age. Your DMF (flywheel) should be fine. So not as expensive as you thought then ;)
hawksy
  • crewe
Re: 2.2dti clutch
« Reply #6 on: 13 October 2010, 11:25:11 »
cheers , thanks for all the help and info , regards mike :)
hawksy
  • crewe
Re: 2.2dti clutch
« Reply #7 on: 15 October 2010, 15:32:05 »
 UPDATE- clutch pedal is now staying down and only comes back up when i pull it back with my foot , also contacted local vauxhall dealer ( bristol st motors ) about price for a dmf ( flywheel ) and they quoted over £ 1000.00 plus clutch at £ 200.00 all plus vat and fitting , so if you know of a flywheel as i believe they are all made by luk  for £150.00 please let me know , regards mike
Welung666
Re: 2.2dti clutch
« Reply #8 on: 15 October 2010, 15:46:21 »
PM on way Mike :y
