Author Topic: Tow ball height  (Read 991 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Tow ball height
« on: 15 October 2010, 19:26:49 »
Can anyboby tell me the tow ball height on their 2.6 facelift saloon, Mine appears quite low and I wonder about the springs The car has only done 68000mls but maybe the springs have been changed to lower the back end.
Re: Tow ball height
« Reply #1 on: 15 October 2010, 19:31:57 »
Don't have a 2.6 to measure ..   my 3.2 is  392mm  ... but this might help anyway ..
http://www.al-ko.co.uk/edit/files/support/Towballguide.pdf
TOWBALL HEIGHT
In all instances it is imperative that the correct towball height specification is met.
Caravan: 430mm +/- 35mm
Car: 385mm +/- 35mm
These measurements are taken on a level surface and represent the distance from the ground to either the centre of the towball or the centre of the coupling head. This requirement is part of EC regulations and must be adhered to.
