Author Topic: steering pulling to the left  (Read 877 times)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« on: 17 October 2010, 16:09:29 »
Hello, in the last 3 months or so i have replaced front discs and pads, w/bones, d/links, tie rods and rear donut bushes. Then I had the tracking done (WIM too far away from me, not gone yet). The car was driving great, in a staright line, no wandering, no pulling on braking.
Anyway while going slow (15-20mph) behind a tractor on country road the front left wheel hit a bad pot hole (couldn't see due to manure everywere). 5 mins later had to brake hard from 50-60 ish to 15 mph due to animal in the road, and the car noticeably pulled to the left, not good.
Ever since I have to correct the car as it aims for the left if you don't adjust the steering wheel, it's not too bad, I can live with it but it's getting on my nerves as it was brilliant before.
Does any one know what the problem is please? I haven't had a look yet.
Also, may be unrelated, but the power steering seems a little heavier which is also a horrible little niggle that's annoying me now. It's got new fluid, but crappy factor stuff. Is this unrelated and should I get some proper VX stuff? Thanks!
TC and BnQ Trade holder.
Re: steering pulling to the left
« Reply #1 on: 17 October 2010, 16:37:46 »
Clearly something shifted since hitting the pot hole. Obviosly question is what? Could be camber slipped, wishbone bush failed, or it's affected the toe setting.
Given your getting a pull to the left on that side under braking I suspect a failed wishbone front bush allowing toe out under load.
What make wishbones fitted?
« Last Edit: 17 October 2010, 16:38:56 by chrisgixer »
geoffr70
  • Sunderland
  • Boobies
« Reply #2 on: 17 October 2010, 17:52:51 »
a cheapo set off ebay! They've only had 1500 miles maximum of easy driving. Surely the can't fail in that distance? It was literally like a switch, fine before, not after.
Well the front tyres are wearing down more so on the inside edges, by sight i can see the camber is out, they lean in at the top alot more than they do on the mv6. I haven't got round to getting it wimmed, the nearest one to me is Mansfield i think.
Is the toe setting done in conjunction with tracking? Thanks
