Author Topic: omega trip computer  (Read 1139 times)
hixey
  • co armagh/northern ireland
omega trip computer
« on: 17 October 2010, 22:00:41 »
i have a 02 omega gls facelift,gls dosnt come with many extras and i want to fit a trip compuer,what all do i need from donner car?most older vauxhalls where wired already for it,is the omega?thanks in advance
Re: omega trip computer
« Reply #1 on: 18 October 2010, 08:48:25 »
The trip computer side of things will be in place. The Check Control side of things won't. Which means you will have to acknowledge about 7 failures every time you start the car.
You could fool the display with sory wiring, as check control items are simple on/off signals.
You will need to check if you have wiring from the wiper stalk to the display as well
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 18 October 2010, 09:59:36 »
What would be needed to install Check Control? The control-unit nturally, some of the sensors are difficult/nearly impossible to retrofit but is there anything else? How does the bulb failure control work? Does it need any re-wiring?
« Reply #3 on: 18 October 2010, 10:17:18 »
The check control would need a bit of wiring. Look at the wiring diagrams to see whats involved.
