Author Topic: 12 - 6 movement  (Read 1118 times)
gary5661
12 - 6 movement
« on: 17 October 2010, 17:15:25 »
front passenger side wheel i have 12 - 6 movement when jacked up no movement 3 - 9, but i cant see where the play is i can feel it though, bottom arm ball joint????
Re: 12 - 6 movement
« Reply #1 on: 17 October 2010, 17:21:39 »
Sounds like play in the wheel bearing. Have a look at this  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1283124735
gary5661
Re: 12 - 6 movement
« Reply #2 on: 17 October 2010, 17:59:33 »
how come you dont get bearing movement side to side?
Welung666
Re: 12 - 6 movement
« Reply #3 on: 17 October 2010, 18:03:00 »
When the car is on it's wheels the weight is pushing upwards, this will cause the play to be significantly more noticable on a 12-6 than a 3-9 as that is where the pressure is normally.
Try getting someone to press the brake pedal and try the 12-6 again. If the movement stops then it's the bearing, if it doesn't then it's something else :y
Re: 12 - 6 movement
« Reply #4 on: 17 October 2010, 18:04:21 »
I would say its bottom ball joint, bearing would give play in 3-9
kcl
  • Finland
    • Volvo V60 D4 -14
Re: 12 - 6 movement
« Reply #5 on: 18 October 2010, 10:27:46 »
I'm with Marks opinion, bearing would be merely in all positions. 3-9 play would be the steering/outer tie rod, 12-6 would be the ball joint.
