Author Topic: V6 facelift spark plug replacement problem.  (Read 1791 times)
Jimmy Jerms
  • Kent/London Border
« on: 18 October 2010, 13:02:58 »
Just replaced the plugs on my V6 but no way could I get to pot 6. Any ideas? Took off the usual air by-pass and wiring loom moved aside but no way could I get a plug spanner to No6.
Also some of the plug bores wer full of engine oil. Where could this be comming from? :-?
Re: V6 facelift spark plug replacement problem.
« Reply #1 on: 18 October 2010, 13:17:42 »
Engine oil will be your camcover gaskets leaking - get them replaced before the oil causes a misfire and takes out your DIS with it (because that's a lot more expensive than just replacing the gaskets)
« Reply #2 on: 18 October 2010, 13:31:19 »
.... but no way could I get to pot 6. Any ideas?  ....
You need a selection of short extension bar & a flexible/universal joint.  ;)
If you think no 6 is bad on a V6, you should try no 6 on a straight six ;)  ;)  ;)
« Reply #3 on: 18 October 2010, 16:52:37 »
Strangely i had no issues with that, much to Omegatoy's annoyance  ;D
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #4 on: 18 October 2010, 20:06:38 »
as already said, use selection of extension bars, I found a few different length wobbler bars to be very useful.
TC and BnQ Trade holder.
« Reply #5 on: 18 October 2010, 20:21:16 »
The S6 was just by comparison. If you have the right tools ie a short extension that comes level-ish with the top of the rocker cover ....  ;) ;)
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #6 on: 18 October 2010, 21:26:30 »
Have a look at picture 16 near the bottom of the guide.  Shows a standard short extension (3"?) on a plug socket even gives you room for a torque wrench.  Worked for me!   :y
I feel like a military academy. Bits of me keep passing out.
tango
  • brum
« Reply #7 on: 18 October 2010, 21:29:45 »
use a short extension to get it open once undone you can pick it up using a short hose pipe
tango
  • brum
« Reply #8 on: 18 October 2010, 21:32:02 »
just to mention once its out make sure when you put in the new one
it is hand tightend using the extention bar on its own,
can be cross threaded very easily if not carefull.
geoffr70
  • Sunderland
  • Boobies
« Reply #9 on: 18 October 2010, 21:40:09 »
use a telescopic magnet (like car aeriel) to get it out well
« Reply #10 on: 18 October 2010, 21:42:28 »
A good spark plug socket should have a short section of rubber tube inside to hold onto the spark plug while  you're putting it in or taking it  out   ..... Oooer!  :-?
« Reply #11 on: 18 October 2010, 21:45:00 »
Or use your tip for removal for insertion - stick a length of vac hose over the end of the spark plug and use that to screw it in until it's well in (plenty of turns) the hose won't turn it anymore.. guarantees you can't cross thread it ;)
