Author Topic: dash bulbs not working  (Read 1554 times)
andyc321
  • reading
  • doh
« on: 15 October 2010, 11:17:35 »
hi all, im a newbie to this however i have a couple of bulbs not working. 1 for the fuel gauge and 1 half of the rev counter. i took the unit out but the bulb elements looked fine. can anyone help me further to solve this??? many thanks  :D
Re: dash bulbs not working
« Reply #1 on: 15 October 2010, 11:26:51 »
Swap the bulbs with the known good ones. Just because they look OK doesn`t mean they are
andyc321
  • reading
  • doh
« Reply #2 on: 15 October 2010, 11:39:04 »
what a muppett i should have thought of that. thankyou very much i will try it and let you know
mantahatch
« Reply #3 on: 15 October 2010, 13:21:01 »
Yes, I had one out, removed dash tested bulb on spare battery and t was working so stupidly put it back in and it did not work. Thinking of problems with printed circuit board took it out again and a friend send test the bulb again, this time t did not work.
I think the moral is whilst it out replace them all.  :y
Filth_Mobile_Jim
  • Cranbrook, Kent
« Reply #4 on: 15 October 2010, 22:34:00 »
I just bought an omega. It was dusk as i drove home. Switched my lights on, and none of the dash illuminated!
 Wasnt till the sun went down further that i saw a very faint back lighting. Then i found the illumination brightness control wheel!!  ::)
« Reply #5 on: 15 October 2010, 22:38:25 »
..... Then i found the illumination brightness control wheel!!  ::)
You're definitely not the first & I doubt you'll be the last.  :y :y :y
andyc321
  • reading
  • doh
« Reply #6 on: 18 October 2010, 12:29:19 »
sorted the bulbs out on the dash, robbed them from the reading lights on the headlining. only trouble is they must have been a slightly higher wattage as they are a bit brighter. oh well new bulbs and all sorted thanks for all replys that helped. much appreciated.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #7 on: 18 October 2010, 19:40:31 »
Should be 2.2 watts
andyc321
  • reading
  • doh
« Reply #8 on: 19 October 2010, 07:18:34 »
thanks pitchfork, i didnt know if they were 2.2 or 3 watts i think i stuck a 5w in one of them. ive got a few spares now i will change them back over this week. thanks again for the info  :y
