Author Topic: Headlight Switch back light change/replace  (Read 1590 times)
deejag94
  • South Wales
« on: 14 October 2010, 00:05:09 »
Omega 2.2 CD ecotec 2002 model
Can anyone help in telling me how to replace the back light bulb in headlight on/off switch please. Thanks
tango
  • brum
Re: Headlight Switch back light change/replace
« Reply #1 on: 14 October 2010, 05:52:47 »
im pretty sure its not a replaceable bulb
hence the unit must be replaced
surely one of the more experienced members will be able to confirm
Welung666
« Reply #2 on: 14 October 2010, 06:07:19 »
They can be replaced. I thought, as Tango does, that they were a permanent fitting bulb. You need to get the headlight switch out, there is a single bulb in the back of the switch itself.
« Last Edit: 14 October 2010, 06:07:33 by Welung666 »
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« Reply #3 on: 14 October 2010, 16:35:58 »
Are there bulbs behind the front and rear foglamp switches that can be replaced as mine are not illuminated?
VOYAGER
  • ANKARA/TURKEY
    • 1998 Omega CD V6 AUTO
« Reply #4 on: 15 October 2010, 15:02:38 »
There should be a topic related to this replacement. Use "search" and you cannot miss it.
Jimmy Jerms
  • Kent/London Border
« Reply #5 on: 20 October 2010, 14:09:08 »
Never tried it on the Omega but had a similar switch module on my old Senator. (Ahhhh that WAS a car). The lamps were not intended for replacement as with all of the illuminated switches but managed to find some small pea lamps with wire connections in Radio Spares catalogue. Removed switch, opened carefully with small driver and blade and soldered the lamps in. Not a difficult job. :)
panderson
  • Ayrshire, Scotland
« Reply #6 on: 20 October 2010, 14:47:38 »
deejag94 - I have exactly the same situation with mine but the bub and it's fitting have come loose.
If you open the drivers door and release the side panel of the dashboard, you get access to behind the switch and I'm sure you'll find that the bulb and its holder have come loose from it's fitting.
I'm still trying to find out exactly where to refit it to but am not that worried as there is still some degree of illumination.
