Author Topic: abs/tc problem  (Read 874 times)
chelski
  • Eastleigh
abs/tc problem
« on: 20 October 2010, 19:36:24 »
hi could anyone help me when driving today abs and tc light came on also power steering was a bit sticky but about half a mile down the road the lights went out i don't want to rush out and buy a abs unit before asking advice first no codes on paper-clip test many thanks
Darren
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: abs/tc problem
« Reply #1 on: 20 October 2010, 19:39:07 »
Abs ecu is gubbed im afraid or on its way out  :-/
« Last Edit: 20 October 2010, 19:39:30 by Mark38 »
Re: abs/tc problem
« Reply #2 on: 20 October 2010, 19:40:21 »
Did speedo also stop for a while ??
If so, classic symptoms of the start of an ABS ECU problem. IMHO just keep an eye on it for a while .. see if it starts to recur regularly. Mine eventually became exceedingly predictable ... wouldn't work for 20 minutes, then worked for an hour, then wouldn't work at all. I'm guessing this was related to temperature - expansion - of the bits inside the ECU.
Fix was to remove the ECU and send it to BBA REMAN for repair.
chelski
  • Eastleigh
Re: abs/tc problem
« Reply #3 on: 20 October 2010, 19:42:23 »
hi mate
is that the unit next to the battery (well just behind). the power steering has been sticky before but no warning lights
