Author Topic: New fuel pump but no power please help  (Read 3350 times)
Stump85
  • Bury St. Edmunds, West Row
« on: 15 October 2010, 19:28:51 »
My motor turns over but will not start, just replaced the fuel pump on it. still nothing. Dont think its the camshaft sensor just replaced it last year. Looking for the fuel relay but not sure where it is. Been without a ride for a week, I would really appreciate the help. Love my car and I dont want to give it up, its a 99 Omega Elite. Thanks alot for your help.
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: New fuel pump but no power please help
« Reply #1 on: 15 October 2010, 19:42:06 »
Hi
Do a paperclip test for fault codes.
Alan
Stump85
« Reply #2 on: 15 October 2010, 20:01:35 »
I will, let you know what it says. Thanks
« Reply #3 on: 15 October 2010, 21:34:27 »
Fuel pump and main engine relays are the 2 purple ones at the back of the triangular box by the battery.
Worth checking both of those.
Does the engine light flash when you're cranking it? If so, likely immobiliser issue.
ballcock50
  • South Wales
« Reply #4 on: 15 October 2010, 21:43:42 »
Had a problem with a v6 a few years back, had no power to pump at fuse but power out of relay so in frustration I linked a supply to pump fuse to start and move the car, after starting removed link and car continued to run had no problem after. :y
« Reply #5 on: 15 October 2010, 22:29:43 »
Knackered crank sensor will prevent fuel to injectors
Stump85
« Reply #6 on: 16 October 2010, 13:48:44 »
Just did the paperclip test getting a 12 and a 34 which means nothing. I dont have the equipment to test the relays so will probably buy a new one. Any other ideas?
jonny66
  • selston, notts
« Reply #7 on: 16 October 2010, 15:15:24 »
i have some spare relays if need be buddy. they came out my gsi veccy but are the same so i believe. :-/ :)
Stump85
« Reply #8 on: 16 October 2010, 15:51:06 »
That would be great, I need a Siemens relay #90459642
Stump85
« Reply #9 on: 18 October 2010, 20:22:27 »
Just had the relay tested today it is good. Gonna hook the battery straight to the fuel pump again tomorrow and see if I missed something. Looks like a good ole tow if that anything else.
Abiton
« Reply #10 on: 18 October 2010, 20:30:42 »
What's the answer to Kevin's question about dash lights when cranking?
Matchless
  • Nottingham
    • A white van
« Reply #11 on: 18 October 2010, 20:40:13 »
On the V6 the fuel pump relay is only turned on once the ecu sees pulses from the crank sensor, ie the immobiliser has to be happy, the engine has to be turning and the crank sensor has to be generating good quality pulses.
ballcock50
  • South Wales
« Reply #12 on: 18 October 2010, 20:57:47 »
I thought the fuel pump ran on ignition on for a few seconds to pressurise the system before start up.
« Reply #13 on: 19 October 2010, 07:53:01 »
Nope.
vauxfan2k
  • Western Isles
« Reply #14 on: 19 October 2010, 17:06:07 »
the 4 pot pressurises the fuel before cranking over, but not every time you turn on the ignition.
I just started the estate (2.5 v6) on monday for the first time in over a year and the pump did not run until the engine was cranked over, even then it only spun over for about 6 seconds before firing up.
If your certain the crank sensor is new/fully working then you should check the wiring to/from its connector, something isnt right.
the car should at least cough
« Last Edit: 19 October 2010, 17:06:50 by Vauxfan2k »
