Author Topic: Traktor EGR pipe  (Read 4892 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Traktor EGR pipe
« on: 18 October 2010, 18:19:17 »
The stainless steel EGR pipe on the Traktor has just fractured - For the 3rd time in 7 years!!!
Does anyone else have similar problems with their BMW engined workhorse?
(Mine has done 160K miles in 14 years)
Re: Traktor EGR pipe
« Reply #1 on: 18 October 2010, 18:40:51 »
I've done away with mine ;)
« Reply #2 on: 18 October 2010, 19:23:50 »
Have you got the middle clip on still?
Where did it break? Where it attaches to exhaust?
Pitchfork
« Reply #3 on: 18 October 2010, 19:30:54 »
Yes middle clip intact on all 3
The first went all around the end at the exhaust end
The second did the same but at the other end
Today's has multiple cracking at the first bend at the exhaust end
The first went around the mouth at the exhast end
« Reply #4 on: 18 October 2010, 19:34:06 »
Hmmm, what can I say, its BMW junk :P
If it keeps going, may be worth taking EP's advice  :-/
Pitchfork
« Reply #5 on: 18 October 2010, 19:36:18 »
But surely getting rid of it increases polution & lowers MPG? It was added for a reason..........
« Reply #6 on: 18 October 2010, 19:46:27 »
I doubt any Omega owner cares that much about pollution, esp Tractor owners ;D
I only had to put 1 egr pipe on mine in the 2yrs i had it, the original had been bodged when I got it.  Got mine from scrappy
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #7 on: 18 October 2010, 20:36:30 »
I have removed mine as well after 2nd went within 3 months...
Kneepad
  • West Scotland
« Reply #8 on: 18 October 2010, 21:07:29 »
I havn't noticed any increase in pollution or reduction in MPG since I blocked mine off.  ;)
Evo
  • Amersham
« Reply #9 on: 19 October 2010, 06:04:55 »
Mine's done 180k in 14 years & no problem. Could it be defective engine mountings allowing too much movement?
You could check by blipping the accelerator with the bonnet open & seeing how much the engine rotates.
Pitchfork
« Reply #10 on: 19 October 2010, 08:37:55 »
But everything is attached to engine at both ends so cannot see how this could be cause :question
Evo
  • Amersham
« Reply #11 on: 19 October 2010, 14:12:25 »
My apologies ... you're right. The other end goes to the exhaust manifold. So not at all obvious as to why they should go. All I can think of is differential thermal expansion causes stress .. but doesn't seem likely.
Pitchfork
« Reply #12 on: 19 October 2010, 15:46:25 »
Aye..........you cannae change the laws of Physics!!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #13 on: 19 October 2010, 18:33:32 »
Have you had the auxiliary belt changed recently?
'Someone' may possibly have levered against it whilst refitting the tensioner damper bracket.
Just a thought .........  :D
osealy
  • dublin
« Reply #14 on: 19 October 2010, 20:47:25 »
Never had that problem. 4 TD's  c 250k mls , most on the one car was 145k (died of no hot start)
