Author Topic: water leak and white smok from exhaust  (Read 1723 times)
manolo
« on: 21 October 2010, 11:49:08 »
Hi,
I have 2.6V6 and last few month have problem  :( with water leak (approx. 0,8litar on 6 month or 6000km)  and also  white smoke from exhaust even motor is warm.
under the  car there is no water (always is dry) and no damage can see on pipes. Radiator is new.
THX
M.
manolo
Re: water leak and white smok from exhaust
« Reply #1 on: 21 October 2010, 12:13:29 »
now I see there may bee blown CYLINDER HEAD GASKET  >:(
http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust
iainb
  • West Midlands
« Reply #2 on: 21 October 2010, 12:17:10 »
Question;
Does your car run ok or do you have a miss fire ?
Have you checked for any codes (try the pedal trick)
Does your car warm up normally.
Is there any water in the oil or oil in the water.
« Reply #3 on: 21 October 2010, 12:18:06 »
I doubt it. You need to find out where the water is leaking from by pressurising the cooling system and having a good look. The V6 does produce alot a vapour anyway ;)
« Reply #4 on: 21 October 2010, 12:22:40 »
there is a simple test which measures the chemical content of coolant.. its connected to the radiator..
not %100 reliable , but will give some idea..
personally I would try that and then start to be suspicious.. :-/
there are many places that miggy can leak and not so visible..
and you can try a rope from plug holes to test also..
« Last Edit: 21 October 2010, 12:24:14 by cem_devecioglu »
manolo
« Reply #5 on: 21 October 2010, 13:43:18 »
Question;
miss fire??? may bee. Hire is a video When I start engine, there is some brbrbrrrrrrrm when press accelerator pedal
http://www.youtube.com/watch?v=OYtQwTaw4ww
error code 1612 and 1613
warm up is normally (may bee little to slow??)
oil in water no, water in oil do not know???
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #6 on: 21 October 2010, 14:58:25 »
Hiya,code p 1612--immobliser no or wrong signal
   code1613--also no or wrong signal.Are you reading the flashes correct? :y
manolo
« Reply #7 on: 21 October 2010, 16:32:08 »
yes, I disconect batery and message disappear  :D
manolo
« Reply #8 on: 22 October 2010, 13:17:11 »
and problem comes back  >:(
but I notice sometimes when start engine it emidiatly turn off and orange service lamp blink. Engine wont start until key is set in "0" position and then start from beginning
after that I get error code 1612 and 1613
what to check?
