Author Topic: Climate Control playing up  (Read 2502 times)
Re: Climate Control playing up
« Reply #15 on: 08 October 2010, 13:55:45 »
Solenoids are interchangeable. Black vac rubber pipes = hbv
black/blue rubber = recirc flap :y
As I don't use recirc at all .... is it worth just swapping the two over ??? Does the recirc use vac as default or no-vac as default ?? If you get my meaning !! (what happens if you put a knackered solenoid on the recirc ??)  :)
Not sure about non-working solenoid on the re-circ as the facelifts utilise an air quality sensor which controls it automatically but if you never use it I can`t see any problems arising just make sure that the flap (behind pollen filter) remains in an open position.
If the solenoid is fubared I`ve got two here + F/L dash sun sensor (black)
Hang on to them for me please ..  we'll see what we find .. :)
« Reply #16 on: 22 October 2010, 14:40:52 »
Had it all apart today .... would appear that neither solenoid is working .. :(  12 Volt is being sent by the controller to both solenoids, but no clicks or feel of movement, and blowing through doesn't change .. :(
So, RobG do you still have the solenoids for sale ?? PM sent anyway ... :)
Also a few other minor bits needed .. looks like "someone" has been in there before.. and not done a very good job ... request going up in "parts wanted" ...  :)
