Author Topic: Adjusting handbrake shoes  (Read 1699 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 22 October 2010, 12:53:32 »
May well have just missed it in the how to . But need to adjust mine as the handle is coming up to far. Any tips on this and the best way to do it.
Thanks
Steve. :y
Re: Adjusting handbrake shoes
« Reply #1 on: 22 October 2010, 12:57:58 »
You missed it, its in the guides :y
SP_3.2
  • Leicester
« Reply #3 on: 22 October 2010, 13:14:46 »
Thanks Jamie.. :y :y.
« Reply #4 on: 22 October 2010, 13:36:10 »
Oh, that's a job for the weekend. You've reminded me. Mine needs re-adjusting since I changed the disks and pads last week.
amba
  • Medway towns
    • German V6
« Reply #5 on: 22 October 2010, 18:04:47 »
I think that has got to be one of the most fiddly jobs on the entire braking system.
I replaced both my back discs and pads today..not before time as the pads had worn a very heavy groove into the o/s disc and the pads had all but disintegrated so just braking via the metal..not good I know.
Have come to the conclusion that with new brake shoes it is only just possible to get the disc /drum on with the little star adjuster wound right in..lever comes up 3 clicks and holds car nicely so hope any adjustment on mine will be a way down the line now as trying to get a screw driver into the inspection hole and turn that little wheel looks like a right game.
Did find MarkDTM suggestion of the 2 pairs of long nose pliers the best sloution to get the cut out washers back on the pins but what a job..you need 4 pairs of hands and patience of JOB.
Anyway my job is now done so brakes have life again.
For referrence to others part numbers are as follows:
Back Dics/Drums.......93182292....£59=77
B
amba
  • Medway towns
    • German V6
« Reply #6 on: 22 October 2010, 18:07:50 »
 Sorry missed of part numbers.
Back Discs/Drums.........93182292........£59=77
Think the part numbers have changed from original guide ..boxed was marked VX but made in Poland.
Above price is less VAT and on Trade Club Card
    • 530D M Sport, 330i Coupe
« Reply #7 on: 22 October 2010, 18:40:07 »
The adjusters aren't too bad as long as you have a torch (LED type seems better for this) to locate them and click them in the right direction each side :-[
Done a few now so probably got the 'knack'
amba
  • Medway towns
    • German V6
« Reply #8 on: 22 October 2010, 19:47:14 »
Your eyes must be alot better than mine !!
It was very sunny today but even with handheld 27 bulb led light I couldn,t see a thing..should have gone to spec savers I suppose ??
I am happy though as with new hand brake shoes fitted to new discs/drums...star adjuster wound fully in and cable adjusted,handbrake lever comes up 4 clicks now and holds car solid.
Job done just recovering from hands/knees working with a fairly large glass of cider.
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #9 on: 22 October 2010, 19:56:40 »
I keep meaning to get 1 of those cheap LED light key rings to butcher, put it on the end of a small diameter tube at right angle, with battery and switch on the other end of the tube...  The inside of the disk should then light enough to see what you are doing, rather than looking at the back of the torch...
Last time I adjusted them, I managed to get a screwdriver holding the spring out of the way whilst I adjusted, which made things much easier...
