Author Topic: head gasket  (Read 2923 times)
pjd7325
  • Dudley, West Midlands
Re: head gasket
« Reply #15 on: 23 October 2010, 00:14:02 »
If you have a head gasket failure you will have oil in the water (expansion tank) which will look like mayonaise and water in the oil again the same. You will also notice a loss in water. There could be a split pipe in your case and as you have no heat the matrix would be a good place to start. It could be a simple air lock (there is a bleed screw on the radiator under the passenger side bumper) Or a blockage somewhere.
One day your life will flash before your eyes...make sure it's worth seeing!!
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: head gasket
« Reply #16 on: 23 October 2010, 08:35:27 »
Thats not true mate. . If the oil cooler has given up there will be oil in the reservoir.
Usually if the head gasket has gone there is water loss without traces, missing, if you remove the reservoir cap then start the car water will bash up as the piston comes up if that makes sense, also i have seen water coming out of the exhaust like a hosepipe.
Hope that helps.   :y
tkstallions
  • St Helens, Merseyside
  • Horses are more reliable hahaha lol
Re: head gasket
« Reply #17 on: 23 October 2010, 14:11:36 »
Hi Tk, you would be better to create your own post, things get confusing when there are multiple queries from different members in the same post.  :y
Thanks for letting me know :y
Vauxhall Omega 1999 T reg 3L MV6 Automatic
