Author Topic: head gasket  (Read 2918 times)
molliemoo060304
  • leicester
head gasket
« on: 23 September 2010, 22:34:25 »
I think my head gasket has had it :( (steam coming from under bonnet, overheating really juddery on acceleration) anyone tell me how much this is going to cost to get fixed? :(
Kneepad
  • West Scotland
Re: head gasket
« Reply #1 on: 23 September 2010, 22:45:22 »
Don't jump to conclusions a bit of info first. Is there any
emulsification inside the oil filler, any signs of that on
the dipstick. Did you see where under the bonnet the steam was coming from.
It could be as simple as a split hose.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: head gasket
« Reply #2 on: 23 September 2010, 22:45:43 »
Could just be a leak in the radiator or one of the coolant hoses... although the head gaskets will go if you allow it to overheat for too long.
You need some-one reliable to diagnose the fault.
Re: head gasket
« Reply #3 on: 23 September 2010, 22:51:00 »
Could be hbv spraying coolant on the dis pac causing a miss fire....
...any signs of mayo on the dip stick meaning water in the oil? Defo hg failed if so, probably not otherwise....probably.
Like your name btw. :y
molliemoo060304
  • leicester
Re: head gasket
« Reply #4 on: 24 September 2010, 07:36:18 »
Hi, I am getting mecahnic to look at it today , steam was coming from the water tank and I have noticed the heater not working for a while as well as some overheating so i think i must have been driving with a broken water pump ...desperately hoping its not the hg but seems likely :(
molliemoo060304
  • leicester
Re: head gasket
« Reply #5 on: 24 September 2010, 07:37:20 »
will check the dipstick this morning
molliemoo060304
  • leicester
Re: head gasket
« Reply #6 on: 24 September 2010, 08:04:44 »
The dipstick is fine but there are small white spots on the oil cap...i'm guessing that this means goodbye car? [smiley=cry.gif]
Re: head gasket
« Reply #7 on: 24 September 2010, 08:14:33 »
mayo on the oil cap is quite normal.
its when its at the bottom of the dipstick you have problems.
Dont think you need to condemn it just yet  :y
Re: head gasket
« Reply #8 on: 24 September 2010, 08:16:57 »
No it doesn't MM ;) emulsified oil (mayonaisse) on the filler cap is normal, it is 99% of the time due to condensation caused by short journeys. If there is no sign of mayonaisse on the sump dipstick, then it may not be the head gasket. I own a 4 pot not a V6, so not too hot on your engine, but someone with more knowledge will be along shortly to help further :y
note: must type faster! :D
« Last Edit: 24 September 2010, 08:17:43 by philrich1064 »
molliemoo060304
  • leicester
Re: head gasket
« Reply #9 on: 24 September 2010, 09:02:25 »
Thanks guys, i do drive short distances a lot (school run) so I wont give up hope just yet...I really love my car and will be gutted if it has to be scrapped [smiley=sad.gif]
Re: head gasket
« Reply #10 on: 24 September 2010, 09:04:22 »
Any recent work.....oil cooler per chance?
molliemoo060304
  • leicester
Re: head gasket
« Reply #11 on: 24 September 2010, 09:10:38 »
had pas pump changed a couple of months ago but thats it...oil check came on the other day but oil level is fine?
tkstallions
  • St Helens, Merseyside
  • Horses are more reliable hahaha lol
Re: head gasket
« Reply #12 on: 22 October 2010, 22:48:51 »
I have the similar problem,  :-? car started running funny/running rough/juddering, then overheated :-[, very little water in tank, very smoky (it looked white, but it was dark), filled the oil up (didn't need filling alot it was in between min & max) & filled the water up(nearly empty), still smoky and overheating (on acceleratin the smoke disappeared more or less until we had to slow down at a junction then speed up again then would kinda disappear again til we had to slow down), heater now not working, managed to get it home, left it over night (it was very late) and looked at it today and it is still smoky, greyey (idoling).pale bluey/tinge of blue (on acceleration), their is no oil in water, it doesn't look like water in oil (just seems thin) no "mayo" on dipstick but mayo in the filler pipe, your thoughts would be most appreciated, i'm hoping it's not cylinder head or gasket ;)
I have a T reg 1999 Omega 3L MV6  :y
« Last Edit: 22 October 2010, 22:50:24 by tkstallions »
Vauxhall Omega 1999 T reg 3L MV6 Automatic
Kneepad
  • West Scotland
Re: head gasket
« Reply #13 on: 22 October 2010, 23:12:27 »
Hi Tk, you would be better to create your own post, things get confusing when there are multiple queries from different members in the same post.  :y
Kneepad
  • West Scotland
Re: head gasket
« Reply #14 on: 22 October 2010, 23:15:28 »
What was his diagnosis ?
