Author Topic: Teach me for being smug  (Read 2468 times)
bluey
  • West Mids
« on: 21 October 2010, 15:31:50 »
While reading lots of posts from esteemed Mig owners I had flown past the various comments about the cam covers leaking, safe in the knowledge that mine were nice and tight and not letting a drop of OPECs finest get away.
Well, while on the way on a 200-mile round trip for a job interview earlier today, I paused to take a call and pulled off at the Frankley services on the M5 to be met with the sight of smoke billowing out from under the bonnet.  It smelt oily so I felt reasonably safe in opening up to take a look, and spotted a lovely huge patch of dark congealed semi-synthetic all over the manifolds.  So that put the mockers on making the job interview and I crawled back the few miles to home, feeling downright annoyed as well as very blimmin' worried about it catching fire.
Called the local dealer and the prices appear to have gone up a fair bit since Mark DTM's nifty guide on sorting this problem out - I just saw the date on it and it was 4 years ago so that's to be expected I guess. The gasket set is £37.78 inc VAT, while the O rings are 19pence each and the sealant is £4.14.
« Last Edit: 21 October 2010, 15:33:36 by bluey »
markh1
  • surrey
Re: Teach me for being smug
« Reply #1 on: 21 October 2010, 15:53:43 »
I am going to tackle this problem on the weekend, my thread here....
http://www.omegaowners.com/forum/YaBB.pl?num=1287578717
....may help in regards to sourcing the parts cheap.
'98 Omega 3.0 Elite Manual - Slowly having most of running gear replaced
'98 TVR Cerbera 4.5 - completely rebuilt on new chassis
bluey
  • West Mids
« Reply #2 on: 21 October 2010, 16:00:46 »
That's excellent and thanks for the info. I will give Andy a call straight away.  :)
« Last Edit: 21 October 2010, 16:00:58 by bluey »
bluey
  • West Mids
« Reply #3 on: 21 October 2010, 16:18:37 »
Can I just say - AndyC, top work fella and thanks for taking the time to sort out a gasket set.  :y
bluey
  • West Mids
« Reply #4 on: 23 October 2010, 14:28:51 »
Right then, the bits arrived this morning and have got my head suitably scratched but I reckon I'll fathom it out pretty quickly.  Reading the how-to guide again to get it in my bonce and I'll start diving in.  This being the first time I've worked on this engine I'll be taking my time, and hopefully will do an oil change afterwards, although I'm a bit suspicious of the filter I have bought - it doesn't look right to me.  Ho hum, I'll find out in time I suppose.
Welung666
« Reply #5 on: 23 October 2010, 17:11:42 »
Give me a shout if you get stuck and I'll come help :y
bluey
  • West Mids
« Reply #6 on: 23 October 2010, 17:38:04 »
I might do just that.  The 4 breather pipes on the rear of the plenum are absolutely refusing to move which is beginning to get right on my moobs!
Welung666
« Reply #7 on: 23 October 2010, 17:47:17 »
Just tease them back with a large(ish) flat blade screwdriver, they tend to bond to the fitting tubes. Be very careful not to snap the thinner 2 in the centre though :y
bluey
  • West Mids
« Reply #8 on: 23 October 2010, 18:05:33 »
I did have a bit of a go broadly as you suggested earlier, but stopped as I was a bit worried about doing any damage to the pipes on the plastic box.  I'll have another go first thing in the morning and see if a bit more worrying of them as you mentioned will do the trick.
Been a bit frustrating, not so much the car but the weather which has been stop/start rain.
While I think about it, the throttle cable - how is it connected to the lever arm?  It looks a bit like a clip-over balljoint of some description but it won't budge even though the retainer clip has been removed.
Welung666
« Reply #9 on: 23 October 2010, 18:07:15 »
They are quite tight but they do pop off (answer applies to both breather pipes and throttle linkage ;) )
PM on it's way now :y
bluey
  • West Mids
« Reply #10 on: 23 October 2010, 18:53:23 »
No worries then, just me being a bit of a nervous nerys in tackling it.  And thanks very much for the PM, hope the reply made some sort of sense.  :)
« Last Edit: 23 October 2010, 18:53:55 by bluey »
Welung666
« Reply #11 on: 23 October 2010, 18:57:17 »
Perfect sense, shame the same can't be said for my reply ;D ;D
markh1
  • surrey
« Reply #12 on: 23 October 2010, 22:00:50 »
I changed my rocker cover gaskets today. Was a fairly straight forward job!
Regards the throttle linkage, I did not notice the small clip and just levered it off with a screw driver. Like the others have said, slide a screw driver under the breather pipes to lever them off. You could also try spraying some silicone or other lubricant under them to help.
At the same time I changed the plugs and also did a mild port and polish on the throttle butterflies. The car is noticeable more responsive now, must have been ages since the plugs were changed!
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #13 on: 23 October 2010, 22:49:51 »
Shoot me if I'm stating the obvious but when you pull a tube it gets longer and thinner.  Longer doesn't matter but thinner makes them grip even tighter.
So, as Welung says, pushing is the way to go.   :y
I feel like a military academy. Bits of me keep passing out.
bluey
  • West Mids
« Reply #14 on: 24 October 2010, 20:50:18 »
Well, after a rather cold day over with Welung the car is now leak free on the one guilty bank and feels far more responsive thanks to the breather system being cleaned out while the various bits were off the car - it doesn't feel slightly asthmatic and reluctant to rev.  As there was a bit of slack in the throttle cable that was ironed out when being put back on and is much better at the pedal.  It's funny how just tiny little details like that can make such a major improvement.
Huge thanks for the help and advice squire, the bad news is that I'll be back to do the cambelt.    ;D :y
« Last Edit: 24 October 2010, 20:50:46 by bluey »
