Author Topic: Tyres  (Read 1679 times)
Stagecoach
  • Fontwell, West Sussex
Tyres
« on: 25 October 2010, 09:31:27 »
Hi. My car has 225/55/16's. I have been offered cheap a pair of 205/55/16's. Will they fit.
Cheers Guys
Omega_Dan
Re: Tyres
« Reply #1 on: 25 October 2010, 09:34:49 »
I dont think so? the section width is quite a bit less. wouldn't risk it anyway :y
Re: Tyres
« Reply #2 on: 25 October 2010, 11:08:01 »
apart from the insurance problem stated by other members in that thread
http://www.omegaowners.com/forum/YaBB.pl?num=1287911392
personally I wont advice.. miggy is a heavy car and definitely you wont be safe on curves .. but will fit..
also you will need speedo correction by tech 2 as the tire diameter of 225 and 205 seriously different..
« Last Edit: 25 October 2010, 11:09:10 by cem_devecioglu »
Diamond Black Geezer
    • & a silly coupe coming...
Re: Tyres
« Reply #3 on: 25 October 2010, 11:27:54 »
Hmmm...As stated on the other thread (-link provided above) and I was the one saying that you'd be ok with 215s - however I think 205 is starting to push it a bit. Rolling radius would be different, cem is quite correct, so speedo will be out
(just done a quick calculation and I make the speedo will be out by 8.8%, though someone with better maths skills than I may give a completely different figure!) So indicated 91.1mph @ actual 100mph (my brain hurts)
As you have an Elite that means you have 7.5J x 16 wheels(?) as opposed to the 7Js that a 205 would run on. So thats nearly an inch NARROWER tyre running on a half-inch WIDER rim.
There are the facts, go forth my son, and do with them what you wish!  :y
Re: Tyres
« Reply #4 on: 25 October 2010, 11:30:37 »
Oh course if these are decent rubber it may well be worth your while sourcing some cheap lower-spec alloys? ie: those designed for 205 rubber. Again, as cem says the speedo will still be out. Depends if you dont mind people thinking you own a CD, instead of and Elite (are people that pedantic where you live?)
bluey
  • West Mids
Re: Tyres
« Reply #5 on: 25 October 2010, 12:07:22 »
Sounds to me that you'd in in danger of spending £50 to save a tenner.  Better to just stick to the correct spec.
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
Re: Tyres
« Reply #6 on: 25 October 2010, 12:45:00 »
Learn something new every day...  I always thought that the profile dealt with the tyre diameter and the tread width the tyre width...
I have thought of changing the tread width of mine to 225 from 205 ('98 GLS spec)...
Re: Tyres
« Reply #7 on: 25 October 2010, 12:54:22 »
Well.. they do ;) But since profile is expressed as a percentage of width, they're related..
So if you drop the width, you'd need to increase the profile to keep the rolling radius the same - this site gives a reasonable approximation of the calculation:
http://www.miata.net/garage/tirecalc.html
(Real world being a bit different due to squish and so on, IIRC)
Psychoca
  • Norfolk
Re: Tyres
« Reply #8 on: 25 October 2010, 13:24:15 »
Yeah, I found one of those...  Just means that I need to change 2 tyres next time instead of just the 1...
