Author Topic: Climate Control vacuum pipes facelift  (Read 1588 times)
BigCat
  • Battersea
« on: 24 October 2010, 17:14:49 »
Hi everyone,
Still trying to fix my Climate Control. At the moment I have no heating, although HBV was changed back in spring.
Have determined if we apply vacuum to the HBV then hot water flows and hot air comes out of vents, otherwise nothing.
What I'm after is a schematic of the vacuum pipes and solenoids inside the passenger compartment. Does anyone have one , or is there one on the forum?
Dominic
The first 90% of a job takes 90% of the time, the last 10% takes the other 90% of the time.
Re: Climate Control vacuum pipes facelift
« Reply #1 on: 24 October 2010, 18:53:43 »
Sorry mate .. your post is unreadable due to the size of your avatar ... :(
Yours is 320 x 240 !!  Site rules .. max 110 x 110 .. so we can actually read what you post !!
« Last Edit: 24 October 2010, 18:55:04 by entwood »
babes99
« Reply #2 on: 24 October 2010, 18:56:19 »
He said  :D
Hi everyone,
Dominic
Abiton
« Reply #3 on: 24 October 2010, 21:13:26 »
Hi everyone,
Dominic
This would suggest that the coolant pipes on the 'output' side of the HBV are interchanged, and need swapping over, I'm fairly sure.
« Reply #4 on: 24 October 2010, 21:20:45 »
Hi everyone,
Dominic
Agreed.. that is WRONG ... should be No Vac = Heat, Vac = Cold   ie, vac turns OFF the water flow. My guess is the HBV is connected up wrongly .....
« Reply #5 on: 24 October 2010, 21:38:59 »
Hi everyone,
Dominic
To OP. The two spigots on the HBV. Top hose into bulkhead fit to top spigot, bottom bulkhead hose to bottom spigot
BigCat
  • Battersea
« Reply #6 on: 26 October 2010, 01:11:22 »
Thanks for the replies.
Problem finally sorted out today; Mechanic says he replaced the the solenoid behind the radio, not sure he was being completely honest with me, but he didn't charge me so I'm not complaining.
BTW: not sure what happened to the avatar, it's the same one I've been using for years. I'll reduce it down.
BigCat
  • Battersea
« Reply #7 on: 26 October 2010, 01:13:07 »
Oh, btw, note to admins: I didn't receive the e-mail notification for the replies.
