Author Topic: side light not working  (Read 1462 times)
gateshead
« on: 25 October 2010, 19:08:17 »
hi guys my passenger side light is not working i have changed the bulb with no joy. also when i leave the indicator on when the engine is off it leaves the lights on, on the side the stalk is left on. front and back. does any body have any ideas were to start. cheers kevin
« Last Edit: 25 October 2010, 19:27:17 by gateshead »
arthill
  • Greenock
  • HI all pleased to join Forum
Re: side light not working
« Reply #1 on: 25 October 2010, 19:17:38 »
Side parking light is operated by indicater stalk, possible wiring fault if sidelight is not working.
jOHN
John
gateshead
« Reply #2 on: 25 October 2010, 19:26:06 »
that was my thinking, looks like a trip to auto electics
Kneepad
  • West Scotland
« Reply #3 on: 25 October 2010, 20:23:44 »
Are you saying the bulb in question does work when the stalk is used for parking, but doesn't when you just use the light switch?
gateshead
« Reply #4 on: 26 October 2010, 12:07:03 »
the bulb does not work at all. but works when i put it in the other side. if i leave the indicator stalk on left or right position it buts the front main beam on and the rear brake light on. it would seem there is a electrical fault some were does any body have any ideas were to start.
« Reply #5 on: 26 October 2010, 12:20:57 »
..... if i leave the indicator stalk on left or right position it buts the front main beam on and the rear brake light on. it would seem there is a electrical fault some were does any body have any ideas were to start.
is this the same whether the ignition is on or off? I'd suggest a dodgy main light switch or indicator switch, but not sure how either might cause the brake light coming on.  :-/  :-/
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 26 October 2010, 12:50:45 »
sounds like it could be a poor earth connection at one of the lights in question causing it to back feed other bulbs
other rides
