Author Topic: ar25/35  (Read 1088 times)
swrkent
  • kent
ar25/35
« on: 26 October 2010, 19:52:40 »
help think my gearbox has given it up getting fault code p0730 gear ratio incorrect which have been told means clutch giving up in box and cant afford £1200 for a refurb  :'(
Kneepad
  • West Scotland
Re: ar25/35
« Reply #1 on: 26 October 2010, 19:58:14 »
Your gearbox is automatic and as such has no clutch to speak of.
Check your fluid level, see how to:
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Re: ar25/35
« Reply #2 on: 26 October 2010, 20:05:03 »
Clutch in this case would almost certainly be referring to 'brake bands' - also known as 'clutch bands' depending on who you talk to ;) If they're slipping and not stalling the right combination of planetary drives then the final output ratio ends up wrong and this code comes up..
Which could be a fluid (low pressure) problem as you say, or a solenoid problem, or a brake band problem, or the thrust bearing on the input end broken down..
Still if it's still doing it after a fluid change I'd be much more inclined to sling a £200 s/hand box on than pay £1200 for a refurb ;)
Kneepad
  • West Scotland
Re: ar25/35
« Reply #3 on: 26 October 2010, 20:17:44 »
sassanach
  • trowbridge
Re: ar25/35
« Reply #4 on: 26 October 2010, 20:57:11 »
if i recall correctly, there are 4 "clutches"and 1 brake band in the ar25/35
sassanach
  • trowbridge
Re: ar25/35
« Reply #5 on: 26 October 2010, 20:58:08 »
what exactly is happening?
