Author Topic: need help with brake lines  (Read 827 times)
chelski
  • Eastleigh
« on: 26 October 2010, 20:56:25 »
hi had a failed abs unit got repaired at bba reman on refitting fine then when bleeding got no fluid through rear brakes does anyone no the pipes correct order on the unit there are letters on each hole can any one explain this please many thanks
Darren
Kneepad
  • West Scotland
Re: need help with brake lines
« Reply #1 on: 26 October 2010, 21:09:11 »
May be out of my depth here, but as I understand it you will have an air lock in the abs unit and will require the use of a Tech 2 to run the actuator in the unit while bleeding, to get fluid through.
Someone will correct me if I'm wrong.
« Reply #2 on: 26 October 2010, 21:11:08 »
